Remote Sensing and Actuation Project
Here's a simplified version of the remote sensing project I am working
on. I currently own a single BS2P40 and I'll probably need a second one,
or maybe a BS2P24. The two stamps will be seperated by a considerable
distance of about 1500 feet (500 meters). A person will be at one
Stamp, let's call that Stamp A, the other, Stamp B will be at the end of
the cable. Stamp B will control 4 variable speed motors and return sensor
data. . Stamp A will be connected to 4 potentiometers and will likely
output sensor data on an LCD display. Because of the distance, I see
an RS-485 system being implemented.
My questions are:
1. How should I organize the sending and receiving of data over the RS485
connection? I understand that I'll need to convert the RS232 data
to/from RS485 data.
2. Should each A to B transmission be something like (motor 1 speed &
direction, motor 2 speed & direction, motor 3 speed & direction, etc.)
followed by a request for Sensor Data from Stamp B
3. Should each B to A transmission be something like (sensor 1 value,
sensor 2 value, sensor 3 value, etc.)
4. Where should I turn to for guidance? I have basic electronics and
software knowledge, a whole mess of shielded twisted pair cable and the
urge to learn.
Ideas,
Chris
________________________________________________________________
GET INTERNET ACCESS FROM JUNO!
Juno offers FREE or PREMIUM Internet access for less!
Join Juno today! For your FREE software, visit:
http://dl.www.juno.com/get/web/.
My questions are:
to/from RS485 data.
urge to learn.
Ideas,
Chris
buildings?
I suggest using FiberOptic cable between buildings.
DS
> one, or maybe a BS2P24. The two stamps will be seperated by a
> considerable distance of about 1500 feet (500 meters). A person
> will be at one Stamp, let's call that Stamp A, the other, Stamp B will
> be at the end of the cable. Stamp B will control 4 variable speed
> motors and return sensor data. . Stamp A will be connected to 4
> potentiometers and will likely output sensor data on an LCD display.
> Because of the distance, I see an RS-485 system being implemented.
> My questions are:
> RS485 connection? I understand that I'll need to convert the RS232
> data to/from RS485 data.
> the urge to learn.
> Ideas,
> Chris
> from the same email address that you subscribed. Text in the Subject
> and Body of the message will be ignored.
apologies if it already came through.
My questions are:
to/from RS485 data.
urge to learn.
Ideas,
Chris
You can easily wind up with a huge difference of potential there.
If your going to use RS485, use good differential level chips or devices or
modules, as they have taken that into consideration.
1. The SERIN or SEROUT functions on most any I/O pin you like, may work as
well as trying the serial port. I'd probably check out the www.maxim-ic.com
web site and look at the
http://dbserv.maxim-ic.com/appnotes.cfm?appnote_number=386 chips shown there
an see if they'd help you out or not.
Yes on 2.
Yes on 3.
Do an internet search on RS485 is a start, lots of info there.
From: veewee77@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=sGJDM2oWzpFG-y3xge-6MFbrel3WHNLCp8SEz6WB69EiEwsyWVztY9Aoi8cXkpBTEVRsEiio0Gv5FvQ]veewee77@a...[/url
Sent: Wednesday, March 13, 2002 9:07 PM
Subject: Re: [noparse][[/noparse]basicstamps] Remote Sensing and Actuation Project
Is this twisted pair cable going to be run outdoors between
buildings?
DS
> My questions are:
> the urge to learn.
> Ideas,
> Chris
Yes it'll be run outdoors, but not between buildings. The F/O sounds
nice but I'm not experienced with this type of transceiver. The
termination of the end of the fiber doesn't thrill me either. Did you
have a particular idea?
Thanks for the comments,
Chris
Date: Wed, 13 Mar 2002 21:06:55 -0600
Subject: Re: Remote Sensing and Actuation Project
buildings?
DS
> My questions are:
> the urge to learn.
> Ideas,
> Chris
> ___________
