Negative Number in a LOOKUP instruction?
Bob-
Your Stamp doesn't handle negative numbers, but subtraction works
fine so long as everything => 0. Try something like this:
RANDOM RandomNumber 'Generate a random number
DieRoll = RandomNumber//6 'Set Direction variable to be between 0 and 5
LOOKUP DieRoll, [noparse][[/noparse]1,0,0,0,1,1], PanRight
LOOKUP DieRoll, [noparse][[/noparse]0,1,1,1,0,0], PanLeft
LOOKUP DieRoll, [noparse][[/noparse]0,1,0,0,0,1], PitchUp
LOOKUP DieRoll, [noparse][[/noparse]0,0,1,0,1,0], PitchDown
FOR X = 1 to 150 'This loop moves the servos to the desired position
PULSOUT PanServo, pancenter + (PanRight * X * 2) - (PanLeft * X * 2) 'Gradually
pan in the appropriate direction
PULSOUT NodServo, nodcenter + (PitchDown * X * 3) - (PitchUp * X * 3) 'Gradually
nod in the appropriate direction
PULSOUT JawServo, jawclosedmax + (X * 2) 'Open the jaw a bit at a time
PAUSE 10
NEXT 'Loop until we've reached our destination
Steve
PAUSE 10
Steve
I wrote the code below to move a servo either to the left or right of center
depending on a die roll. Well, the LOOKUP instructions work fine, but of course
they put a very large postive number into the variable instead of a -1 (two's
complement, right?). The servo slams all the way over to the right, instead of
gradually moving to the left. So what's an easy way to fix this? I've already
got a workaround by changing the -1 values to a postive value (I used "2"), and
then testing and branching if the direction variable = 2 to a different formula
(pancenter - (X*2)). Is there a better way to do this?
Thanks in advance!
Bob Pony
Here's the code:
LOOKUP DieRoll, [noparse][[/noparse]1,-1,-1,-1,1,1], PanDirection 'Assign appropriate Pan value
[noparse][[/noparse]R,UL,DL,L,DR,UR]
LOOKUP DieRoll, [noparse][[/noparse]0,-1,1,0,1,-1], NodDirection 'Assign appropriate Nod value
PULSOUT PanServo, pancenter + (PanDirection * X * 2) 'Gradually pan in the
PULSOUT NodServo, nodcenter + (NodDirection * X * 3) 'Gradually nod in the
PAUSE 10
byte variable. When left panning is specified, the LOOKUP statement
yields -1, or 65535 as the 16-bit workspace result, but stores only
the low order 8 bits in panDirection. When the variable is recalled
later for the calculation, its 8 bits are padded with 8 leading
zeroes, giving a 16-bit intermediate value of $00FF, or 255. 255 *
X * 2 then results in a large, non-negative number which is then
added to pancenter, producing a rapid right panning instead. This
is a longer version of my earlier, simplistic remark regarding the
Stamp's ability to handle negative numbers.
Please correct as required. I'd like to be sure I understand how
this works.
Steve
> >Well, the LOOKUP instructions work fine, but of course they put a
> >instead of gradually moving to the left. So what's an easy way to
> >fix this?
> >Pan value [noparse][[/noparse]R,UL,DL,L,DR,UR]
> It is true that the -1 in twos complement is represented as 65535.
> Multiplication works fine under twos complement (division does
> not!). If you multiply out, say, 65535*5*2, and then discard the
> upper 16 bits, you get 65526, which is the correct twos complement
> representation of -10. When added to pancenter, it should give the
> correct result. I am puzzled why the servo slams against the wrong
> stop.
> -- Tracy
Bob
Sent: Friday, March 08, 2002 2:06 PM
Subject: Re: [noparse][[/noparse]basicstamps] Negative Number in a LOOKUP instruction?
> Bob-
'Gradually pan in the appropriate direction
'Gradually nod in the appropriate direction
> PAUSE 10
> Regards,
> Steve
>fix this?
Multiplication works fine under twos complement (division does not!).
If you multiply out, say, 65535*5*2, and then discard the upper 16
stop.
-- Tracy
I just changed PanDirection and NodDirection from byte variable to word
variables and the original code works fine now. Thanks for catching that.
It makes perfect sense. Fortunately I've got plenty of RAM left, otherwise
I'd use your earlier suggestion of multiple LOOKUP statements and a modified
formula.
Both are good solutions. Thanks so much for the help with this guys!
Cheers,
Bob Pony
Sent: Saturday, March 09, 2002 5:13 AM
> Here's what I think is happening. I'm guessing PanDirection is a
> this works.
> Regards,
> Steve
> > >fix this?
> > stop.
> > -- Tracy
