Proximity Switch and count Function
I am trying to build a wind speed indicator and decided to use a
proximity switch and a Basic Stamp 2 to count the switch closures and
then calibrate the wind speed from the total count. The problem I am
having is I can not get a consistent reading from the proximity
switch. The readings are all over the map (From 0 sometimes up to 150)
as I try and trigger the prox. The code I am using is as follows:
'($StampBS2)
Speed Var Word
Again:
Count 1, 500, Speed
Debug CLS, Dec ?, Speed
Low 1
Goto Again
Note I had to add the Low 1 command to get any type of reading. Any
help would be appreaciated.
Thanks Loren
'($StampBS2)
Speed Var Word
Again:
Count 1, 500, Speed
Low 1
Goto Again
Thanks Loren
you refer to is a magnetic reed switch, it will tend to bounce a
number of times as it closes and give you multiple counts where you
expect only one. You can "debounce" it with a resistor and a
capacitor:
2.2k switch
_
+Vdd ----/\/\
o o
o---Vss common
1k |
P0 ----o----/\/\
o
===== 0.1 debounce |
-- regards,
Tracy Allen
mailto:tracy@e...
http://www.emesystems.com
>'($StampBS2)
>Speed Var Word
>Again:
>Count 1, 500, Speed
>Low 1
>Goto Again
>Thanks Loren
on the high side of the switch, not on ground.
Clark Hughes
Tracy Allen wrote:
> The problem may be in the hardware hookup. If the proximity switch
> capacitor:
> 2.2k switch
> _
> +Vdd ----/\/\
o o
o---Vss common
> 1k |
> P0 ----o----/\/\
o
> -- regards,
> Tracy Allen
> mailto:tracy@e...
>was to tap in on the high side of the switch, not on ground.
>Clark Hughes
Hi Clark, You're absolutely right. Here it is, moved over:
2.2k switch
_
+Vdd ----/\/\--o---o o
o---Vss common
1k |
P0 ----o----/\/\
o
===== 0.1 |
Too early in the morning. A professor I worked with told us always
to sneak an obvious error onto the blackboard at the beginning of a
lecture. There was bound to be somebody who would speak up about it,
and wake everyone up and open up discussion. If not, assume everyone
is already asleep!
-- Tracy
>> capacitor:
> > 2.2k switch
>> _
>> +Vdd ----/\/\
o o
o---Vss common
>> 1k |
>> P0 ----o----/\/\
o
>> -- regards,
>> Tracy Allen
>> mailto:tracy@e...
coming from the prox switch. Power, ground, and the load, where do I
put the resistor and the capacitor.
Thanks Loren
--- In basicstamps@y..., Tracy Allen <tracy@e...> wrote:
> >Might want to double check that schematic. I think the intention
> >Clark Hughes
> 2.2k switch
> _
o---Vss common
> 1k |
> P0 ----o----/\/\
o
> ===== 0.1 |
it,
everyone
> is already asleep!
> -- Tracy
switch
you
> >> capacitor:
> > > 2.2k switch
> >> _
> >> +Vdd ----/\/\
o o
o---Vss common
> >> 1k |
> >> P0 ----o----/\/\
o
> >> -- regards,
> >> Tracy Allen
> >> mailto:tracy@e...
Okay, it is not a reed relay. What part number is the prox switch?
Does it need a pull-up or pull-down resistor?
sensor.
If it is....
They usually come in four variants - PNP & NPN
....and Normally Open or Normally Closed.
On an NPN you put the load between load and power.
PNP types between load and ground.
How many volts are you applying to its power
lead?. The ones I use (for wheel speed sensing
take between 10 & 35 volts DC). They work down to
8(ish) volts, but no lower.
Hope that helps
Les Otter
> From: Tracy Allen [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=PVbX1ytg2vfEyJEU6u434kRnN5gzImUAFW9D8HlQVri7x3ChaE6qu26orlmLHmdENryeMOKmVeQaviFosew]tracy@e...[/url
> Sent: 08 March 2002 21:58
> Subject: [noparse][[/noparse]basicstamps] Re: Proximity
> >Hi Tracy, I am not understanding your
> schematic. I have three leads
> from the same email address that you
> subscribed. Text in the Subject and
> Body of the message will be ignored.
> >Hi Tracy, I am not understanding your schematic. I have three
leads
I
Tracy, I am using a Allen bradley Prox # 871C-D2NP8 - E2 A and
presently not using a pull-up pull-down resistor.
Loren
Normally, you should use a load resistor. The output device of the sensor is
often a transistor with an open collector connexion. You need to supply this
collector via a resistor. If it's a PNP output, you must connect a resistor
between output and negative side of the power supply. If it's a NPN, the
resistor must be between output and positive side of the power supply. If
you omit the resistor, the output is like floating, and the Stamp input is
not properly driven, giving erratic measures.
Best regards,
Phil.
> Loren
Thanks for the help.
Loren
--- In basicstamps@y..., "Derenne Philippe" <derennep@s...> wrote:
> Hi,
sensor is
supply this
resistor
NPN, the
supply. If
input is
> Best regards,
> Phil.
> > Loren
