PAK 8 operation
Hey Al Williams, it's me again!
I'm back on my motor-speed-control-using-a-PAK8 project. The multiple
PWM outputs and serial addressing were just what I needed to control
several motors (and optionally the braking and directions) with one
Stamp.
Got my mechanical issues sorted out, got the timing figured (needed a
tiny pause after the time base command to let it "take"), and even
the command structure (must send values MSBit first, even though 16
bit values are sent LSByte first). Whew.
Now I've got an app killer (wanted a killer app). I'm using this in
an RC controlled vehicle, so the pulse counts (=PWM duty cycle) are
resent a few times a second for smooth response. Every time I update
the values, the output pin seems to go high for a moment, then the
new PWM cycle starts... hard to tell with my old analog scope. This
causes a severe judder in the motors at the update frequency... if I
can't get around this, I go back to my (obsolete and hard to find)
Intersil CDP68HC68's, which made smooth transitions...
Help! and thanks, Pat Matthews
Stamp.
use to do PWM and it makes the change from a single command so you
shouldn't get any jitter there.
The PAK-VIII is a pulse generator, so you are probably computing your
own off and on times to get your PWM duty cycle. The problem is you
can't set them both at the exact same time, so I'd guess that for a
split second you have an "odd" PWM value in the registers. The changes
take place at the end of the cycle, so you could have this scenario:
Start on for 5 units, off for 5 units. (50%)
You decide to go to 30% (3 on, 7 off)
You set 3 on, you are now getting 3 on, 5 off (37.5%)
Then you set 7 off. Now you are at 30%
If you went the other way, you get 5/12 = 41% before going to 30%.
Does that sound like it would explain what you are seeing? There should
be no pause in the cycle generation other than what you program, but
there will be a time when you are using an old half cycle time and a new
half cycle time. That is, unless you are purposely disabling the pin
while making changes.
If your outputs can float, that might be the answer. Set the pin to Hi-Z
before making your change. Then reenable the pin after setting the right
duty cycle. However, if you have pull ups on the outputs this will cause
the "momentarily on" issue you are seeing.
Does any of this sound like what's happening?
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: y2patmat [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=2rNiPa0d2uw3qNYx3Blc2PPw9uX_EMOtxk_cY_DaxhrR1UVh04V8p9NH2EsACwXi9iQMFamdcF4Z]patmat2350@a...[/url
> Sent: Sunday, March 03, 2002 3:14 PM
> Subject: [noparse][[/noparse]basicstamps] PAK 8 operation
> Stamp.
> from the same email address that you subscribed. Text in the
