Dig a little - there's plenty out there...
Try Jon Williams' stuff on the parallax site www.paralaxinc.com using the
DS1302, or perhaps Peter Anderson's www.phanderson.com nice detaile DS1302
explanations.
Hello. There are many different types of RTCs that can be interfaced
with the BS2. There are 1-wire, 2-wire (usually referred to as I2C)
and 3-wire (referred to as SPI or microwire). Parallax has done a
nice job providing a tutorial for the DS1302 RTC. This is a 3-wire
device meaning you need 3 Stamp pins to control it. The 3-wires
consist of a clock, data and chip select. Other 3-wire devices can be
added to the same clock and data line, although you will need another
pin to for the new chip select (i.e. two 3-wire devices would require
four Stamp pins: clock, data, chip select 1, chip select 2). Doing a
search on Parallax's website should produce the DS1302 tutorial.
I2C devices have the advantage of needing only two wires, data and
clock, regardless of the number of devices connected. (I believe
there is a maximum of 64 or 128 devices that can share the same buss,
however). Each chip has a unique identifier (usually a 7-bit ID). The
BS2p has builtin commands for I2C communication (i2cin and i2cout).
Interfacing 2-wire devices is a breeze. Don't worry if you don't have
a BS2p, though. It just takes a little more code to do the same
thing. I've created a tutorial that covers interfacing the DS1307
real time clock to the BS1. Sample software is included and shows how
to set and read the time. The complete tutorial can be found at: http://www.high-techgarage.com/tutorial/ds1307.php. You can buy a
tutorial kit with the RTC, crystal and pull-up resistors as well. We
also offer products which add a RTC and EEPROM to the Stamp. They can
be found in the "Products" section of our website.
From: Chris Loiacono [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=nn8vLpFvfs6H9Yfj6pjIcy7uaS1ZQNfAipsnN1_gizgeyGerl4mbXQCt-OaRrHPQ0ZgUTyx59aBdedNd]chris@m...[/url
Sent: Saturday, March 02, 2002 4:41 PM
To: 'basicstamps@yahoogroups.com'
Subject: RE: [noparse][[/noparse]basicstamps] Real Time Chips with BS@
explanations.
Chris
> From: deaskew [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=wvj3EZexMaHkhm-hnfFu0pgJ2oyNGarkW3I3cLYHUR6aywLUQBnKxLrZ7HUUEaks7dHu0SrgBvlU9fDv]DAVECUSTOM@A...[/url
> Sent: Saturday, March 02, 2002 6:45 AM
> Subject: [noparse][[/noparse]basicstamps] Real Time Chips with BS@
> Has anyone interfaced a Real Time Clock chip with the BS2 Chip. Need
> software help.
Good luck with your project!
--Jeff
Add a RTC and up to 256k EEPROM to your STAMP!
http://www.high-techgarage.com/products/timekeeper3.php
Need
> software help.
