pin 24 on BS2sx
Hi
I was wondering if I can directly hook up a 9V battery to pin 24 in
order to power up the BS2, etc? Or, do I need to add some caps, etc.
for caution? The manual says that the BS2 has an internal voltage
regualtor, and if I put in any voltage >5V on pin 24, that it would
be ok. However, I would like to make sure, before trying this out.
DS
DS
the onboard regulator limits. Pin 21 provides 5V from the Stamp regulator.
-- Jon Williams
-- Parallax
In a message dated 2/28/02 9:07:27 PM Central Standard Time,
debu_sen_22@y... writes:
it worked. But, when I put it again, it didn't work. And now it
does not work by putting a 9V to that pin at all.
Any ideas? I need some help!
DS
--- In basicstamps@y..., jonwms@a... wrote:
> Yes, you can connect a 9V battery to pin 24. Just be sure you
don't exceed
regulator.
> -- Jon Williams
> -- Parallax
in
etc.
voltage
would
out.
the battery up backward did you ?
Bruce
debu_sen_22 wrote:
> Ok... I was afraid of this... but, I put a 9V directly to pin 24, and
> DS
> don't exceed
> regulator.
> > -- Jon Williams
> > -- Parallax
> in
> etc.
> voltage
> would
> out.
second..then when i connected it again, and since then, its not
working...
--- In basicstamps@y..., Bruce <bsnowde@a...> wrote:
> I would use a diode to ensure proper polarity. You didn't
accidently connect the battery up backward did you ?
> Bruce
and
> > DS
> > don't exceed
> > regulator.
> > > -- Jon Williams
> > > -- Parallax
24
> > in
caps,
> > etc.
> > voltage
> > would
> > out.
> > basicstamps-unsubscribe@y...
Subject and Body of the message will be ignored.
working...
> Bruce
and
> > DS
> > don't exceed
> > regulator.
> > > -- Jon Williams
> > > -- Parallax
24
> > in
caps,
> > etc.
> > voltage
> > would
> > out.
I was looking at my Board of Education and if I use a 9V battery it is
directly connected to Pin 24. Also I
looked at my Basic Stamp II carrier board and it is also directly connected to
Pin 24. So connecting a 9V battery
to Pin 24 should be OK.
I also looked in the Basic Stamp Programing Manual 2.0b and for Pin 24 here
are the specs;
BS2-IC 5.5 to 15 VDC and maybe unconnected if 5 volts is
applied
to VDD (+5V) Pin 21.
BS2-IC rev. e 6 to 40 VDC and maybe unconnected if 5 volts is
applied
BS2e 5.5 to 12 VDC (7.5 recommended), and maybe
unconnected
if 5 volts is applied to VDD (+5V) Pin
21.
BS2sx 5.5 to 12 VDC (7.5 recommended), and maybe
unconnected
21.
BS2p24 5.5 to 12 VDC (7.5 recommended), and maybe
unconnected
21.
When you are not sure refer to the PDF files on the Parrallax or Stamps in
Class web sites. and use these for
guidelines.
I have been doing electronics for 30+ years and I still look at data sheets and
books on common devices even if I
am certain that the information I know is correct.
Dale
debu_sen_22 wrote:
> Hi
> DS
My problem is that I did directly connect the 9V to pin 24, and it
did work. But, now it is not (and I tried a new battery on it too),
and I do not know why it is not working now. When I check the pin, i
get 9V, but, the program says that "No basic Stamps found". And,
when I check the VDD pin, there is no voltage there either.
any ideas?
thanks
--- In basicstamps@y..., Dale Fleischmann <fleidale@c...> wrote:
> Hi
battery it is directly connected to Pin 24. Also I
connected to Pin 24. So connecting a 9V battery
Pin 24 here are the specs;
volts is applied
maybe unconnected
VDD (+5V) Pin 21.
maybe unconnected
VDD (+5V) Pin 21.
maybe unconnected
VDD (+5V) Pin 21.
or Stamps in Class web sites. and use these for
> guidelines.
data sheets and books on common devices even if I
> Dale
> debu_sen_22 wrote:
> > Hi
in
etc.
would
out.
> > DS
