serial Protocol
This should get you started. If you specify 8N1 to SEROUT, it will
send one start bit, then 8 data bits (transmitted least significant
bit first) from the your variable, then one stop bit (10 bits all
told). Serial data sent 701 has one start bit, then 7 data bits, an
odd parity bit, and finally a stop bit--again, a total of 10 bits.
The trick is to make the eighth data bit serve as an odd parity bit.
So prior to the SEROUT, you take your 7-bit value, calculate odd
parity and stuff the result in the high-order bit, then send the
result as N81. To the receiver, it will look just like 7O1.
This should generate the odd parity bit for a 7-bit value contained
in "outbyte":
outbyte.BIT7 = 1 ^ outbyte.BIT6 ^ outbyte.BIT5 ^ outbyte.BIT4 ^
outbyte.BIT3 ^ outbyte.BIT2 ^ outbyte.BIT1 ^ outbyte.BIT0
After this instruction the high order bit serves as the parity bit
for 7O1 even when the byte is transmitted as 8N1, because the
receiver interprets the first seven data bits as data and the last
data bit as the parity bit.
Steve
> Can anyone help me i need to communicate at BAUD=9600 PARITY=O
> DATA=7 STOP=1 and the manual seems to tell me i can't, can
> anyone clear this up for me???
> I have Been told that Using 8N1 and or in the high bit as needed to
> make it come out to odd parity...
in "outbyte":
Steve
make it come out to odd parity will work but i have only been playing
with the stamp 2 for 2 days, how would you do what was discribed???
Andy
>Andy
Hi Andy,
Calculate parity of a 7-bit code as follows:
code var byte ' send lower 7 bits of this
parity var code.bit7 ' the most sig. bit of code
parity=1 ^ code.bit0 ^ code.bit1 ^ code.bit2 ^ code.bit3 ^
code.bit4 ^ code.bit5 ^ code.bit6
debug bin8 code,cr ' show it as binary
The"^" in Stampese means "exlusive OR" and is a way of adding
together the bits. You could also use "+". I always get confused
about which is even and which is odd parity, but with odd parity, the
sum of all the bits in the code (including the parity bit) should be
odd. This URL for reference:
http://www.rad.com/networks/1994/err_con/parity.htm
I hope that helps,
-- Tracy
perfectly.....thanks.......
followed the serial protocol to the tee and i can't get the firmware
version to send back the response. Can someone help. My goal is to
make an object file loader on win ce and to use the BSII for my
classroom experiments. I have succeeded in win 98 and win ce up to
the point i mentioned.
Curtis
you need to be more specific about your problem and code.
There are a few tings to take into account.
1. the BS echoes each character you send
2. to download object code or identify the stamp you have to
send a reset and break condition first.
3. watch out not to keep the reset line high and hold the BS in
reset state.
and some more
Regards
Adrian
Thanks for your response. I started with one mscomm
control and three timer controls. I set dtr and the
comm break for the right number of ms as per the
parallax serial protocol document. The on comm event
was used to trap responses and a case statement made
the choice of what to send next. Each time i received
the right return from the stamp except when the
firmware version was checked. When I sent a "0" in
the identify sequence, I get back a "0" but no
firmware version or anything. Thats as for as i got.
I tried everything. Iam using VB 5.0. The reset
works i am pretty sure becuase the simple program in
the bsII which i have an led blinking ten times
resets. I also wrote the same program on a win ce
pocket pc using nsbasic ce and i have the same
problem. My goal is to load an object(hex) file
generated by the BSII ide and load to the stamp using
my pocket pc. I don't think the present tokenizer dll
will work on ce. Parallax states they will come out
with a ce dll in the future. I have developed a number
of experiment for the BSII including a paper
chromatography reader using the toas sensor. I would
like to create a module based educational tool using
the BSII oem and different modules to teach science
with. I will be glad to publish all my projects when
complete for everyone to use free. Thanks for your
help.
Curtis Desselles
--- Adrian Schneider <adrian.schneider@t...>
wrote:
> I did that successful with C++ on Linux. My be I can
> help, but
> code.
> have to
> hold the BS in
> reset state.
> and some more
> Regards
> Adrian
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do you Yahoo!?
Yahoo! Tax Center - File online, calculators, forms, and more
http://tax.yahoo.com
