string comparison
Hi
Is there any way to compare a string with a variable in PBASIC?
the following is my code:
serin 1, 1021,[noparse][[/noparse]WAIT(".1"), STR data_in\5]
if data_in = "fwd1z" then FORWARD
if data_in = "rgt1z" then RIGHT
if data_in = "lft1z" then LEFT
if data_in = "rev1z" then REVERSE
if data_in = "stp1z" then STOP
if data_in = "sen1z" then SENSOR
Now, is there any easier way then having to access each array element
and comparing it?
Debu
and comparing it?
Debu
help you out:
For i=0 to 4
LOOKUP i,[noparse][[/noparse]"f","w","d","1","z"],tst
if data_in[noparse][[/noparse]i]<>tst then nogo1
Next
Equalt_to_fwd1z:
' do whatever
Goto somewhere_else
Nogo1:
' do some more tests
This gets tedious after awhile. You could put your strings in EEPROM
using DATA and then use READ, so you could make a subroutine:
Match:
match=0 ' assume no match
ctest=mystrings-5
Matchtop:
ctest=ctest+5 ' next string
for i=0 to 4
read ctest+i,nxtchar
if nxtchar=0 then ret
if data_in[noparse][[/noparse]i]<>nxtchar then Matchtop
next
' found it!
Match=(ctest-mystrings)/5+1 ' match is equal to 1, 2, 3, etc.
Ret:
return
Mystrings: data "f","g","1","z","0"
data "c","m","d","0","2"
data 0 ' end of list
Then you could use Branch after this call to jump around.
Warning: I'm half awake a 0650, so this might be off a bit, but the idea
should be sound. I'm sure someone will point out my mistakes :-)
Good luck!
Al Williams
AWC
* 8 channels of PWM
http://www.al-williams.com/awce/pak5.htm
> From: debu_sen_22 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=lNk5RB3KNBA-dK0gOSD__bmSxjGL55bzWwgNHKEb65eq53-cnbmr03YT6OzxdJ6SakcSb8eFJIs6MSjLQ8nm]debu_sen_22@y...[/url
> Sent: Wednesday, February 27, 2002 8:45 PM
> Subject: [noparse][[/noparse]basicstamps] string comparison
> Hi
> and comparing it?
> Debu
> from the same email address that you subscribed. Text in the
