I2c code explanation
What you're seeing has to do with a BS2p syntax requirement that expects an
byte (usually an internal address) before reading data from an I2C device. I
simply re-send the control byte in this position. You're right, the device
doesn't need it, but tolerates the retransmission.
-- Jon Williams
In a message dated 2/27/02 9:45:48 AM Central Standard Time,
ricky@m... writes:
> Ok its slowly coming together. I finally got the code working for my Max128
> A/D. Some things just are not very clear to me and if someone could
> explain something to me I would greatly appreciate it. The code below came
> off the parallax site for the PCF8591 A/D. In the I2Cout command below,
> the last part of the command is a byte sized variable called aout. What is
> the purpose of this byte? After giving out the D2a_Enable command, = to
> %01000000, is this not all the stamp needs to send to the A/D for it to
> begin working? And what would the value of aOut be at this point in the
> command?
-- Jon Williams
ricky@m... writes:
> command?
Some things just are not very clear to me and if someone could explain
something to me I would greatly appreciate it. The code below came off the
parallax site for the PCF8591 A/D. In the I2Cout command below, the last part
of the command is a byte sized variable called aout. What is the purpose of
this byte? After giving out the D2a_Enable command, = to %01000000, is this not
all the stamp needs to send to the A/D for it to begin working? And what would
the value of aOut be at this point in the command?
I2Cpin CON 8 ' SDA on 8; SCL on 9
[noparse][[/noparse] Constants ]
DevType CON %1001 << 4 ' device type
DevAddr CON %000 << 1 ' address = %000 -> %111
Wr8591 CON DevType | DevAddr ' write to PCF8591
Rd8591 CON Wr8591 | 1 ' read from PCF8591
D2A_Enable CON %01000000 ' enable analog output
Auto_Inc CON %00000100 ' auto inc a2d channels
MVPB CON $139C ' millivolts per bit factor
[noparse][[/noparse] Variables ]
aOut VAR Byte ' analog out value
aIn VAR Byte(4) ' analog input channels
mVolts VAR Word ' convert to millivolts
dummy VAR mVolts.LowByte
chan VAR Nib ' channel
[noparse][[/noparse] Initialization ]
'Initialize:
DEBUG CLS ' call DEBUG window
PAUSE 250 ' let it open
Main:
DEBUG Home, "PCF8591 Demo"
Set_D2A:
DEBUG Home, CR, CR, "D2A Out........ ", DEC aOut, " ", CR
I2COUT I2Cpin, Wr8591, D2A_Enable, [noparse][[/noparse]aOut]
Get_A2D:
I2CIN I2Cpin, Rd8591, (D2A_Enable | Auto_Inc), [noparse][[/noparse]dummy, STR aIn\4]
FOR chan = 0 TO 3
DEBUG "Channel ", DEC1 chan, " In... ", DEC aIn(chan), " ", Tab
mVolts = aIn(chan) */ MVPB
DEBUG "(", DEC mVolts DIG 3, ".", DEC3 mVolts, " volts)", CR
NEXT
PAUSE 500 ' delay between updates
aOut = aOut + 1 ' increment analog output
GOTO Set_D2A ' go again
END
Sent: Wednesday, February 27, 2002 8:17 AM
Subject: Re: [noparse][[/noparse]basicstamps] I2c code explanation
an
I
device
> -- Jon Williams
> ricky@m... writes:
Max128
came
is
> > command?
