mosfet trouble
Hello,
I'm trying to turn the power of an adjustable regulator (LM317 type)
on and off using a mosfet (IRF-510) as described in the stamp faq on
Al Williams' web site. http://www.al-williams.com/wd5gnr/stampfaq.htm
The mosfet gate is connected to a stamp pin, the source is connected
to +12 and the drain goes into the positive lead of the regulator.
The problem is that the mosfet is always conducting regardless of the
signal coming out of the stamp. I've tried a pulldown resistor on
the gate pin, and i replaced the mosfet with a new one, but no
success.
Can someone tell me what is going wrong here?
Stewart
Stewart Mayer, stewlist@k... on 2/25/2002
success.
Stewart
connected to ground, the same ground as the Stamp (Vss). I'm not sure where
you want to connect the drain of the MOSFET in your application. Could you
explain your circuit in more detail?
Greg
Stewart Mayer wrote:
>Hello,
>success.
>Thanks,
> Stewart
and the drain goes to the voltage input of the regulator. Essentially I have
the mosfet working as a switch because normally the input of the regulator
would be directly connected to +12.
The regulator is not directly connected to ground, it has Vin, Vout, and an
Adjust pin that is connected to ground through a resistor. If it was a fixed
78xx regulator then it would have a path to ground and might work. I suppose I
could interrupt the output power at ground instead of at Vin. I would also
have to interrupt the weak ground connection to the adjust pin so power isn't
sucked when it is off. I'll try that and see if it works.
Stewart
On Tue, 26 Feb 2002 10:18:19 -0600, Gregory D Wagner wrote:
>For a Stamp I/O pin to switch a MOSFET on and off the source needs to be
Stewart Mayer, stewlist@k... on 02/26/2002
ground and the gate to a Stamp I/O pin you can almost shut the regulator
down. A +5V on the gate would turn the MOSFET on and essentially make R2=0.
The minimum output voltage is 1.25V since Vo=1.25(1+R2/R1).
Greg
>That sounds like the problem. The source pin of the mosfet is connected
>to +12
>suppose I
>Thanks,
> Stewart
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
>connected to +12 and the drain goes to the voltage input of the
>regulator. Essentially I have the mosfet working as a switch because
>normally the input of the regulator would be directly connected to
>+12.
It sounds like the circuit you have (or should have) uses a p-channel
mosfet switch. (not n-channel) The trouble is, you can't turn off
that p-mosfet directly from the stamp pin, which outputs a maximum of
5 volts, because it takes 12 volts on the gate to turn it off (OFF
happens when gate voltage=source voltage, and ON happens when gate
voltage is less than source voltage by more than about 3 volts).
The usual trick is to use a second mosfet or transistor in open drain
mode to translate the voltage from the Stamp up to 12 volts:
p-ch _______
+12--o
;-; ;----| LM317 |-o-- out
| R | gate | |
`-/\/\-- o o-/\/\-'
| | R
stamp ||-; n-ch / R
P0---||-| \
Vss Vss
-- Tracy
<BASEFONT FACE="Arial" SIZE="4" COLOR="#000000">
</HEAD>
<BODY bgcolor="#DFDFDF">
<div>Thank you Tracy, I'm just getting into mosfets and transistors, and this
helps very much. I like your ASCII art!</div>
<div> </div>
<div>Stewart</div>
<div align="center">
<table BORDER="1" width = "100%"><tr><td WIDTH="50%"><br>
<FONT COLOR="#000080">>It sounds like the circuit you have (or </FONT><FONT
COLOR="#000080">should have) uses a p-channel</FONT><br>
<FONT COLOR="#000080">>mosfet switch. (not n-channel) The trouble
</FONT><FONT COLOR="#000080">is, you can't turn off</FONT><br>
<FONT COLOR="#000080">>that p-mosfet directly from the stamp pin,
</FONT><FONT COLOR="#000080">which outputs a maximum of</FONT><br>
<FONT COLOR="#000080">>5 volts, because it takes 12 volts on the </FONT><FONT
COLOR="#000080">gate to turn it off (OFF</FONT><br>
<FONT COLOR="#000080">>happens when gate voltage=source </FONT><FONT
COLOR="#000080">voltage, and ON happens when gate</FONT><br>
<FONT COLOR="#000080">>voltage is less than source voltage by </FONT><FONT
COLOR="#000080"> more than about 3 volts).</FONT><br>
<FONT COLOR="#000080">>The usual trick is to use a second mosfet </FONT><FONT
COLOR="#000080">or transistor in open drain</FONT><br>
<FONT COLOR="#000080">>mode to translate the voltage from the </FONT><FONT
COLOR="#000080">Stamp up to 12 volts:</FONT><br>
<FONT COLOR="#000080">></FONT><br>
<FONT COLOR="#000080">>p-ch _______</FONT><br>
<FONT COLOR="#000080">>+12--o
;-; ;----| LM317 |-o-- out</FONT><br>
<FONT COLOR="#000080">>| =====
|</FONT><br>
<FONT COLOR="#000080">>| R | gate |
|</FONT><br>
<FONT COLOR="#000080">>`-/\/\-- o
o-/\/\-'</FONT><br>
<FONT COLOR="#000080">>| |
R</FONT><br>
<FONT COLOR="#000080">>||-' \</FONT><br>
<FONT COLOR="#000080">>stamp ||-; n-ch /
R</FONT><br>
<FONT COLOR="#000080">>P0---||-|
\</FONT><br>
<FONT COLOR="#000080">>| |</FONT><br>
<FONT COLOR="#000080">>Vss Vss</FONT><br>
<FONT COLOR="#000080">>-- Tracy</FONT><br>
<br>
</td>
<td WIDTH="25%" COLSPAN=2> </td>
<td WIDTH="13%"> <FONT COLOR="#000080"></FONT></td>
</tr>
<tr><td WIDTH="50%"> </td>
</tr>
</tr>
</table></div>
<div>-- </div>
<div>Stewart Mayer, stewlist@k... on 02/27/2002</div>
</body></html>
