Javelin Stamp WAS:San Francisco EmbeddedSystemsConference / Stamp Courses
Same guy hit me with a virus in a docs.scr attachment, trapped before it
did anything. Real sneaky doing a reply to your e-mail, even cutting out
some of your comments to respond to. Makes your first thought be that it
is real.
Subject:
Re: Re: [noparse][[/noparse]basicstamps] LED Resistor one more question
Date:
Sun, 24 Feb 2002 21:01:13 -0500
"Nilaweera" <ndharmashri@c...>
To:
<w2ec@a...>
'Ray, W2EC' wrote:
- Hi again Jay,
- Don't worry about where the resistor is, it can be between the STAMP
pin
- and the LED, or between the LED and ground. Think of the LED and
- resistor as two separate water pipes attached together, with water
- flowing instead of electrical current. The water/current has to flow
- between the STAMP pin and ground and it doesn't matter which order the
- two "pipes" are connected in.
- Your dad is sorta correct, depends on whether you are talking "elect
> Take a look to the attachment.
docs.scr
Name:
docs.scr
Type:
Screen Saver
(application/x-unknown-content-type-scrfile)
Encoding:
base64
Rodent wrote:
> Looks like we have another virus running rampant. There was a CARD.PIF file
> attached to this message.
> From: "Nilaweera" <ndharmashri@c...>
> To: <daweasel@s...>
> Sent: Sunday, February 24, 2002 8:01 PM
> Subject: Re: Re: [noparse][[/noparse]basicstamps] RE:Javelin Stamp WAS:San Francisco Embedded
> 'Rodent' wrote:
> - Its unfair to compare Stamp stuff with things that run on a PC -- how much
> - RAM does your PC have and how fast is the processor? Small / compact
> - solutions often require you to think differently and work around what
> appear
> - to be limitations in your mind. Not too many things you can't do with a
> - Stamp or two, you just have to know how to get there. Al and Jon can tell
> - you that.
> - > If that information is accurate, I still don't see f ...'
is real.
Subject:
Date:
To:
<w2ec@a...>
'Ray, W2EC' wrote:
- Hi again Jay,
pin
docs.scr
Name:
docs.scr
Type:
Screen Saver
Encoding:
base64
> To: <daweasel@s...>
> appear
> - you that.
