Ds1616
I have a DS1616 (real time clock, 8 bit temperature
and 2024 recorder) and I cant comunicate with it using
the BS2.
If someone knows how can I comunicate with the device
please let me know,,,,, !!!
Thank you very much
Alex
__________________________________________________
Do You Yahoo!?
Yahoo! Sports - Coverage of the 2002 Olympic Games
http://sports.yahoo.com
the BS2.
Thank you very much
Alex
Do You Yahoo!?
>the BS2.
>Thank you very much
>Alex
Alex -
How you access is depends on which communications method are you attempting
to use. The DSS1611 permits either RS-232 type and 3-wire type
communications. Which one is recognized is determined by the state of the
COMSEL Pin. If COMSEL
is LOW the chip expects to have RS-232 communication used (Serin/Serout). If
COMSEL is HIGH the 3-Wire method of communications will be used.
Since the 3-Wire method appears to require the use of the _INT Pin it might
be best to use the RS-232 Method. If the 3-Wire Method is REQUIRED for your
application there MAY be a way to deal with it.
Which method were you attempting to use ?
Bruce Bates
