making my own cable - what kind of connector do i need
hi...i recently ordered bs2 chip (not the whole kit) and now i'm
trying to build my own cable but can't get it to work. I have found
some websites that has all the instruction to build serial cable but
either they don't have part numbers listed or they don't have
pictures to show exactly what needs to be connected to what and how.
I have db9 female connector and i got the 4 conductor cable but then
I've been reading about some connector that i need but can't find it
anywhere. The one i found does not fit on my breadboard.
Can anyone of you redirect me or tell me what exactly i need and how
do i make it happen?
up an IC socket or just solder pins on the ends of the wires and plug
them in. Pins 2,3,4, and 5 connect straight to the Stamp. Pin 6 and 7 on
the DB9 should be shorted together. So you are 90% there. You just need
a way to connect the DB9 to the Stamp. What kind of connector do you
have for the other end?
You can also get an adapter from us that is mechanically pretty sturdy
and also lets you hook a 9V battery to the breadboard.
http://www.al-williams.com/awce/asp2.htm
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
> From: sam_26880 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pyVdE4rJ9IoJeqF_J0yS3lFGUtX2ZNdmkS2bHD2bM31of4mNyigkBfUFC_UfGN9Y-asAiOaXiArP-lKfPEo]sam_26880@y...[/url
> Sent: Saturday, February 23, 2002 1:08 PM
> Subject: [noparse][[/noparse]basicstamps] making my own cable - what kind of
> connector do i need
> and how. I have db9 female connector and i got the 4
> conductor cable but then I've been reading about some
> from the same email address that you subscribed. Text in the
describes? It's very easy! You only need a DB9 Female, the 4 conductor cable
and a Snappable Header Pin, of at least, 4 connectors. So you can solder
the cable to the DB9, and the other part of the cable to the Header Pin. The
Header Pin is extreamly easy to use in protoboards and PCBs. You can buy
Header Pin in Jameco, JDR, or you local Electronic Store.
Ezequiel Leonardo Aceto
Sunixs Micro
Bernal,
Argentina.
Ezequiel Leonardo Aceto wrote:
> Why don't you try to make the cable connection as the Basic Stamp manual
> Sunixs Micro
> Bernal,
> Argentina.
it. Just solder the cable wires to some clipped off component leads and plug
them into the breadboard.
I cut the cable of an old destroyed mouse.
it is thin, flexible and already with an plug
how to connect it to the stamp it's to see in the manual
regards Heinz
Sent: Saturday, February 23, 2002 8:08 PM
Subject: [noparse][[/noparse]basicstamps] making my own cable - what kind of connector do i
need
local radioshack and they don't have it..and how do i connect it?
manual
conductor cable
solder
Pin. The
buy
> Sunixs Micro
> Bernal,
> Argentina.
a serial cable a figure out what kind of connector you need to mate it
to a breadboard maybe you should consider buying one from Parallax.
leroy
sam_26880 wrote:
> what exactly does it look like? the header pin i meant..i checked
> manual
> conductor cable
> solder
> Pin. The
> buy
> > Sunixs Micro
> > Bernal,
> > Argentina.
