pulsin and temperatur sensor SMT 160-30
hi :-)
I use stamp2p
and try to ad an temp-sensor
the SMT 160 is an Pulse-width modulated temp-sensor
frequency is between 1 and 4 kHz
The duty cycl is direct proportional to the temperature.
So I thought it is very easy to use with the pulsin command
td var word
tp var word
pulsin 1,1,td
pulsin 1,0,tp
and some calculations and finish..............
but..
when I use debug "td= ",dec td," tp= ",dec tp,cr
I get : td= 146 tp= 223 (about 18°C)
The problem now is:
W i t h o u t changing the temperature I get sometimes
"td" and "tp" changed from 146 to 151
= 5* 0,75µSec ... it is too much
after my calculations I got a different of 1-2°C
W i t h o u t changing the temperature !!
it should be 0.2°C max (datasheet)
I added 100nF directly on the sensors supply leg
No change
Is the pulsin command counting very exactly?
I also used a loop and a counter to read the pulse
But the pulse is to short I arrived only about 10 loops
Has somebody an idea what else I could check or think about?
Or what could be wrong?
A nice day to every body Heinz
I use stamp2p
td var word
tp var word
pulsin 1,1,td
pulsin 1,0,tp
but..
The problem now is:
No change
"So to achieve the wished accuracy it is necessary to sample over more than
one sensor period. This way of working has also the advantage to filter
noise."
Here's a subroutine that takes five samples and returns the temperature:
Get_SMT160_Temp:
tHigh = 0
tLow = 0
FOR x = 1 TO 5
PULSIN Tpin, 1, pWidth
tHigh = tHigh + (pWidth / 5)
PULSIN Tpin, 0, pWidth
tHigh = tLow + (pWidth / 5)
NEXT
' temperature = (duty - 32) / 0.47
tempC = (tHigh * 100) / tLow ' calc duty cycle
tempC = (tempC - 32)
tempC = (tempC * 2) + (tempC ** $20AE) ' = tempC * 2.12765
RETURN
The PULSIN accuracy of the BS2p is 0.75 uS -- way beyond what you need to
read this sensor accurately. According the spec, an accuracy of 50 mS will
give a temperature accuracty of 0.1C.
Please not that I don't have a sensor to test with, I wrote this code against
the spec sheet. HTH.
-- Jon Williams
-- Parallax
In a message dated 2/21/02 9:14:13 AM Central Standard Time, hschwenk@g...
writes:
> I use stamp2p
> td var word
> tp var word
> pulsin 1,1,td
> pulsin 1,0,tp
> but..
> The problem now is:
hi Jon,
t h a n k s! for Your quick response Heinz
Sent: Thursday, February 21, 2002 6:16 PM
Subject: Re: [noparse][[/noparse]basicstamps] pulsin and temperatur sensor SMT 160-30
The spec sheet says this:
noise."
Get_SMT160_Temp:
tHigh = 0
tLow = 0
FOR x = 1 TO 5
NEXT
RETURN
against
-- Jon Williams
-- Parallax
hschwenk@g...
writes:
> I use stamp2p
> td var word
> tp var word
> pulsin 1,1,td
> pulsin 1,0,tp
> but..
> The problem now is:
