Help wiring 74HCT161 4-Bit Binary Counter
Hi, does anyone know how to wire the 74HCT161 counter with a 555 chip? I
put pin3 of the 555 to pin2 on the 74HCT161 to increment the timer. For the
74HCT161, I use pin11-14 to light some LEDs, put pin 15 to Vcc, pins
1,8,9,10 to the GND. All the LEDs light up at the same time, slightly
blinking, can anyone help with this or have samples?
Tony
Tony
my National Semiconductors data sheets, you will find a pdf for the chip
that you can down load.
The url is http://www.lennard.net.nz
Look under the listing of TTL Mil Spec IC's for a 54161. This IC is exactly
the same in terms of functions and pinouts, it's just that the 54 series are
military spec.
Cheers,
Ben, Windy Wellington, New Zealand.
http://www.lennard.net.nz/
Ben Lennard, NCEE, Dip EE
Web Hosting and Electronics R&D
Club Coordinator, Victoria University of Wellington Hockey Club
Hm: +64 4 972 7567
Mb: +64 21 536 627
87 Spencer Street
Crofton Downs
Wellington
New Zealand
"To the optimist, the glass is half full. To the pessimist, the glass is
half empty. To the engineer, the glass is twice as big as it needs to be."
No animals were harmed in the transmission of this email, although the
Dog next door is living on borrowed time, let me tell you! Those of you
with an overwhelming fear of the unknown will be gratified to learn that
there is no hidden message revealed by reading this warning backwards.
Subject: [noparse][[/noparse]basicstamps] Help wiring 74HCT161 4-Bit Binary Counter
Date: Thu, 21 Feb 2002 7:40 PM
Tony
Let pin 15 (Carry Out) float.
Greg
>Thanks,
>Tony
attached the 74HCT161 to another 74HCT161 to try to make it count up to 8
bits. Pin 15 is set to high when the bits reach HHHH, then I attached that
pin to the clock of the other chip at pin 2. But that produces the wrong
count because when HHHH is reached it starts the next chip on H000, so the
result is HHHHH000, after that its 0000H000, which is wrong.
It would be better if Pin 15 was set high after HHHH, then it would make
more sense. How do I resolve this counting problem?
Tony
From: Gregory D Wagner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zzdIb_wX5PubVE699yXuMIK3aeo1G0udA57ck8b4AifxHwT5qqbhv5OBS6bTL3F9_G_S1i4hkzrDggN3EIPx-ms]gregory-wagner@u...[/url
Sent: Thursday, February 21, 2002 7:09 AM
Subject: Re: [noparse][[/noparse]basicstamps] Help wiring 74HCT161 4-Bit Binary Counter
Instead of tieing pins 1 (CLR), 9 (LOAD), 10 (T) to GND tie them to Vcc.
Greg
the
>Thanks,
>Tony
'161. Also, connect the clock to both '161s Clock (2). This is a
synchronous configuration so you lessen the likelihood of invalid states
due to ripple.
Greg
>Hi thanks for the advice, it worked great. I have another problem now, I
>Thanks,
>Tony
>From: Gregory D Wagner [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pqvu6mVcuz7nn_1Q4DHf1ei9Eu9PI1lHfxAKfFUwptuIBAmKlKIEAX1o_v641Yfc3H-1FoA4Yn51UOfZSO6l0oU]gregory-wagner@u...[/url
>Greg
>the
> >Thanks,
> >Tony
