INEX-100 board...
In a message dated 2/18/02 3:27:38 PM Central Standard Time,
geneb@d... writes:
> Is the 9 pin programming connector set up so a "normal" straight thru 9
> pin serial cable can be used for programming or do I need to build a new
Yes -- it's "normal." Any off-the-shelf serial cable will work.
-- Jon Williams
-- Parallax
geneb@d... writes:
-- Jon Williams
-- Parallax
cable?
Thanks!
g.
"I'm not crazy, I'm plausibly off-nominal!"
http://www.f15sim.com - The only one of its kind.
> geneb@d... writes:
> -- Jon Williams
> -- Parallax
Glad to hear it. Thanks for the lightnigh fast response Jon!
g.
