How to use a timer function and monitor the in
One simple (maybe too simple for your application) solution:
- tie process control line low through pulldown resistor so default
state is low
- connect emergency stop switch between ground and Stamp reset pin
- when start button is pressed, drive process control line high
and start PAUSE
- if at any time emergency stop switch is activated, Stamp
program will stop, process control pin will revert to input state
and line will be pulled low--when switch deactivated, program starts
all over again
Steve
On 18 Feb 02 at 13:33, sh961610@1... wrote:
> Can anybody help me, I'm having a problem, I want to have a function
> as follows.
> I want to start a project with a start button. I want the stamp to
> hold an output high for an amount of time and then make it low
> again. During this timing I want to be able to read the other button
> for e.g. a emergency stop. I want to be able to stop the process
> before it reaches the end.
> When I use the pause command, I cannot control or read anything
> else!
> Help!
> [noparse][[/noparse]Non-text portions of this message have been removed]
> from the same email address that you subscribed. Text in the
state is low
and start PAUSE
all over again
Steve
> as follows.
> else!
> Help!
slow down the system and shut off some outputs before I can turn off
the stamp. If I would just reset the stamp I have a real emergency!!!
Big troubles if this happenes!!!!!
Thanks anyway,
Greetings Marko
> state is low
> and start PAUSE
starts
> all over again
> Regards,
> Steve
function
> > as follows.
button
> > else!
> > Help!
> > basicstamps-unsubscribe@y...
