My BS2 is not anymore detected by PC after an overload . . . . .
I connected a >>5 Volts at athe input of the BS2, I think the PIC is
still alive but it is not anymore detected by my PC, I guess the
National IC in the chip is the one broken, can this be still repaired?
From: mysemicon2000 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=GfVl-xLUn4Uvce65U5k3FaNPZra5O-MkubmcHSsKUMbhnRJNSNw2ITc1iWsSbUdIsSBIey5MrXvQP2herb52hJN5kcUPXeM]semiconductor@p...[/url
Sent: Friday, February 15, 2002 11:59 PM
Subject: [noparse][[/noparse]basicstamps] My BS2 is not anymore detected by PC after an
overload . . . . .
--- In basicstamps@y..., "Chris Loiacono \(E-mail\)" <chris01@t...>
wrote:
> How much greater than, greater than, 5V?
> From: mysemicon2000 [noparse][[/noparse]mailto:semiconductor@p...]
> To: basicstamps@y...
> overload . . . . .
repaired?
> basicstamps-unsubscribe@y...
Subject and
cannot power up the BS2, btw, what is its function in the BS2 IC?
--- In basicstamps@y..., "mysemicon2000" <semiconductor@p...> wrote:
> About 10 V.
an
> > overload . . . . .
is
> repaired?
> Subject and
> I gues it is the LM293 IC that was broken, it changed its colour
and
> > About 10 V.
<chris01@t...>
after
> an
> > > overload . . . . .
PIC
> is
> > repaired?
> > Subject and
>..Is the LM293 an OP AMP or Regulator.
You should find a "6" on there too, it is an LM2936. It is a voltage
regulator, low power low dropout. It is a jelly-bean part available
from all the large distributors. If you put the 10 volts at Vin
(pin 24), what appears on the +5 output (pin 21)? If that is also 10
volts, the regulator failed as a short circuit and that would not
bode well at all for the PIC chip. But if it is voltage is zero or
at least less than 6 volts, then the regulator may have failed as an
open circuit and you can have more hope that replacing the LM2936 or
at least bypassing it with another power supply will bring your stamp
back to life.
-- Tracy
Can I use other regulators?
and
voltage
available
10
an
stamp
> back to life.
> -- Tracy
