Photo Resistors
For those of you who use or would like to use photo resistors but have
trouble with the RCTime function or dislike using it because of the extra
capacitor assembly here is an alterntive solution.
Tie one end of your photo resistor to ground (I use the Parallax PRs) and the
other end to 5 VDC through a 470 ohm resistor. Take the 470/PR junction to
an ADC input. Using a TLC2543 ADC - 12-bit - and with the PR about 30 inches
from my lamp I get raw readings of about 1800 unshaded and about 4000 with
the PR covered. This disparity is more than enough to give an excellent
control range. I write
if AD0 < 2000 then LEDoff
if AD0 > 3000 then LEDOn
If you can turn an LED off or on, then you can close a relay, open a door,
bake a cake or whatever. I strongly recommend the TLC2543 - it is 12-bit,
11-channel and easy to program. With 11 channels you can monitor 11
locations or events with only 4 I/O lines, and that's a pretty good I/O
utilization. Keep your programming as clean as possible to reduce overhead
and improve the ADC- driven response. No more capacitors, nor calculating RC
times.
Thought you might be interested.
Sid - W4EKQ
times.
Sid - W4EKQ
Cc: <JonWms@a...>
Sent: Friday, February 15, 2002 3:39 PM
Subject: [noparse][[/noparse]basicstamps] Photo Resistors
the
to
inches
overhead
RC
> times.
> Sid - W4EKQ
You can get them from Digikey. Price is about $7.50, which is much less than
a 2- or 4-channel.
Sid
divider such that the photoresistor pin reads high on off and low on on
(or ther other way around)... that's what I did, it didn't require ADC or
anything, just resistors and a cds photocell.
On Fri, 15 Feb 2002, tad heckaman.com wrote:
> What is the price of that chip and where I can get one?
> From: <Newzed@a...>
> Cc: <JonWms@a...>
> the
> to
> inches
> overhead
> RC
> > times.
> > Sid - W4EKQ
Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
email: lamont@a... WWW: http://www.serv.net
"...There's no moral, it's just a lot of stuff that happens". - H. Simpson
What you say is true but can you control a relay or a motor with it?
Sid
