Help for newbie in robotics
Hi Folks,
I've been an occiasional contributor in this newsgroup, and now its my turn
to ask some newbie questions!!
I want to build a little robot to keep my 5y old and my 7 cats amused.
I've got a workshop etc so I can build a base and screw motors in etc,
but I would appreciate some pointers on where I can get motor and gear sets
etc, and H-driver boards that are compatible with stamps.
Any help would be appreciated!
Tony Wells
Tony Wells
Well, newbies unite! I am a newbie robot builder myself. A few months ago I
started to turn RC cars into autonomous robots using a basic stamp. If you
want to drive a DC motor there are a few steps you should take before you
can choose a H-bridge. First of all, you should get an idea of the max.
current throug the coils of the motor. The max. current is the current when
you stall the motor (hold axis fixed, connect power and measure the
current). Depending on that current value, you should choose your motor.
There are some nifty H-bridge IC's on the market that allow you to interface
some low power motors. I have experience with the L293 (upto 1Amp) and the
LM298 (upto 2Amp). If your motor is using much more current, you would
probably have to build your H-bridge yourself. It is not that difficult, but
takes more time. I used TIP120 transistors in a prototype.
here is a link to get you started:
http://www.acroname.com/robotics/info/articles/drivers/drivers.html
good luck,
Matthijs
From: tony.wells@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-XMANr1O7ipxhrroCZzNLAIOFeDe4Xsei8KmMRWdj1ADnVR35i3lfHOOaDV8cn8jjB7Kbic-NkGYaosVZrYmTA]tony.wells@a...[/url
Sent: Friday, February 15, 2002 16:52
Subject: [noparse][[/noparse]basicstamps] Help for newbie in robotics
Hi Folks,
Tony Wells
I hadn't thought about using an RC car - of course all the motor bits are in
place, plus servos for steering etc.
Thanks for the tip.
Anyone else with ideas?
T
Sent: Saturday, February 16, 2002 10:13 AM
Subject: RE: [noparse][[/noparse]basicstamps] Help for newbie in robotics
> Hi there!
I
when
interface
but
> good luck,
> Matthijs
> From: tony.wells@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1z2C5W3_ahkRylhrBFbmHIbmYEH9opIgcl7RXzSMMrKrN8FJP2cN6tZGZYR_c-ziHqE4f16x_b2YB395uQ]tony.wells@a...[/url
> Hi Folks,
turn
sets
> Thanks,
> Tony Wells
RC servo motors make wonderful drive motors for autonomous robots. A
trivial hack converts them to free rotation, and they are then very
easily controlled using PWM from the Stamp (or any other MCU). Plus
they are relatively inexpensive at less than 10 $US each (shop
around!). Check out the robotics section of the Parallax website.
You don't need to buy any of their kits to get the info- but it is
easier that way...for those of us who are less mechanically inclined...
Good luck, and have fun-
peter
Date: Saturday, February 16, 2002 6:49 am
Subject: Re: [noparse][[/noparse]basicstamps] Help for newbie in robotics
> Hi Matthijs
> bits are in
> Thanks for the tip.
> T
You are the 2nd person to mention RC control - it looks like the way to go..
Tony
Sent: Monday, February 18, 2002 9:05 PM
> Tony-
> peter
> From: <tony.wells@a...>
> > Hi Matthijs
> > bits are in
> > Thanks for the tip.
> > T
pcharles@m... writes:
Just for clarification, use the PULSOUT command for driving servos with the
BASIC Stamp (The Stamp PWM command is intended for D2A). Servos do, indeed,
make great little motors as our BOE-Bot so aptly demonstrates.
For detailed information on servo programming, check out our Robotics text.
It is available for download from www.stampsinclass.com.
-- Jon Williams
-- Parallax
