line adressing for 20x4 LCD
Tobie-
The character positions on your display may be thought of as
numbered as follows (decimal):
0,1,2...17,18,19
64,65,66...81,82,83
20,21,22...37,38,39
84,85,86...101,102,103
As Jon pointed out, line 3 is a continuation of line 1, and line 4 is
a continuation of line 2.
You can cause the device to act like a 4-line display if you provide
some code to control it in that manner. What your Stamp must do is
keep track (a byte variable) of the current position on the LCD,
then modify the positon address as needed.
For instance, after writing to position 19, you must command the LCD
to reposition to 64 (use the DDRAM address set command) before
writing the next character. Similarly for positions 83, 39 and 103.
Alternatively, you can recover the current DDRAM addres from the LCD
rather than track the number with a Stamp variable. This requires
an extra Stamp pin (can't just hardwire R/W low), but gives you the
added capability to read back the DDRAM contents as well, which in
turn allows more smarts in your display (shift lines up, smart word
wrapping, etc.).
If none of this makes sense to you, you need to get your hands on a
good HD44780 functional description. I like:
http://home.iae.nl/users/pouweha/lcd/lcd.shtml
I'd suggest a single subroutine that's called every time you want to
write a character to the LCD. That subroutine would keep track of
things and tweak the LCD position as needed.
Steve
On 14 Feb 02 at 12:10, tobiekerridge wrote:
> I'm starting to tinker with a 20x4 character lcd and have an
> immediate problem with lond strings, which write to lines 1, 3, 2
> and then line 4.
0,1,2...17,18,19
64,65,66...81,82,83
20,21,22...37,38,39
wrapping, etc.).
Steve
> and then line 4.
and then line 4.
Is there a way I can change this behaviour throughout my
program without having to create a sub routine everytime I want
to send a string? Any code suggestions would be greatly
appreciated.
Tobie
lines split and interleaved. As you noted, this can lead to problems. With
a 4x20 display there are no "hidden" character positions. About the only
thing you can do is plan your program so that a string doesn't overwrite the
end of the physical display and cause an undesired wrap-around.
-- Jon Williams
-- Parallax
In a message dated 2/14/02 6:10:54 AM Central Standard Time, tobie@m...
writes:
> and then line 4.
If you're working with a BS2p, I'd try something like:
SERIN serial_pin,baud,[noparse][[/noparse]SPSTR 21] ' get packet into scratchpad
GET 0,line_num ' retrieve line # from scratchpad
LCDCMD lcd_pin, 128 + ( line_num & 1 * 64 ) + ( line_num & 2 * 10 )
FOR i = 1 TO 21 ' send data from scratchpad to LCD
GET i,temp
LCDOUT lcd_pin,0,[noparse][[/noparse] temp ]
NEXT
The LCDCMD line is designed to set the display position to 0 for line
0, 64 for line 1, 20 for line 2, 84 for line 3.
If your Stamp is not a BS2p, then you have no native LCD commands and
no SPSTR capability and things get more fun. If you're working with
a BS1 or BS2 you also have no scratchpad and things get much more
fun (read the manual regarding the use of STR\n to see how to use the
variable space as a string array in various instructions).
Steve
this all makes sense, in one way it is what I most feared, on the
other hand it will serve as an exercise to understand the ins and
outs of stamp programming!
I'm going to send my strings in 21 charater "packets" and grab
them with SERIN, the first charater will be an identifier for the line
number.
Is there any way to have a string variable return its nth character,
in fact is there any way to manipulate strings without putting
each character into an array?
this is fun though!
