Size Limit of EEPROM
Use a serial EEPROM as data storage for datalogger, the bigger the size the
better. But, is there any size limit for the EEPROM? Is the max addressing
is 256?
Liang Ji
is 256?
Liang Ji
>is 256?
>Liang Ji
There is really no size limit. There is a matter of programming
convenience in addressing the EEPROM. The word size on a Stamp is 16
bits, for storing values from 0 to 65535. Those could be addresses
in your EEPROM. But that is not a hard limit if you are willing to
use more than one word to store the address.
You will send the address to the EEPROM (via SPI or I2C typically)
before you write or retrieve the data byte(s) at that address. If
you have multiple EEPROM chips, you have to "parse" the address while
sending it so that the correct EEPROM will respond.
-- Tracy
