lcd backlight
I have a samsung lcd module 40x2 with backlight.
I turn on the backlight led and I saw that the the
backlight is demanding 1.025 Amp.
I would like to know if its normal? and if its ok how
can I reduce the demanding.
Thank you very much
Alex
--- "David E. Basile" <dbasile@r...> wrote:
> You might try here. I did a quick seach and didn't
> see it but you might
> look around and find something.
> http://www.eio.com/lcdintro.htm
> HTH
> David
> From: "Alejandro Vazquez" <alexvazquez@y...>
> To: "Yahoo Groups" <basicstamps@yahoogroups.com>;
> "Seattle Robotics"
> <seattlerobotics@egroups.com>
> Sent: Tuesday, February 12, 2002 2:05 PM
> Subject: [noparse][[/noparse]basicstamps] uc-20401
> > Hello,, I have a LCD MODULE UC-20401 is 40x2
> character
> > LCD.
> > I would like to know if someone knows the
> > specefications or have the datasheet of the LCD.
> > Thanks
> > Alex
> > __________________________________________________
> > Do You Yahoo!?
> > Send FREE Valentine eCards with Yahoo! Greetings!
> > http://greetings.yahoo.com
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@yahoogroups.com
> > from the same email address that you subscribed.
> Text in the Subject and
> Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
> Text in the Subject and Body of the message will be
> ignored.
Do You Yahoo!?
Thank you very much
Alex
> HTH
> David
> "Seattle Robotics"
> character
> > LCD.
> > Thanks
> > Alex
> > Do You Yahoo!?
> ignored.
Do You Yahoo!?
series or you could damage the backlight.
From: Alejandro Vazquez [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=o0-8LwKtVyq8gm916CtKB0bvEiSj8MA7tIWNUPaahV0X-soRbs1s2c3bwtXN-GIAnpZQv_P6L5k0zbF21w]alexvazquez@y...[/url
Sent: Tuesday, February 12, 2002 9:11 PM
Subject: Re: [noparse][[/noparse]basicstamps] lcd backlight
Thank you very much
Alex
> HTH
> David
> "Seattle Robotics"
> character
> > LCD.
> > Thanks
> > Alex
> > Do You Yahoo!?
> ignored.
Do You Yahoo!?
on. I had to run it through a 4001 diode to get the voltage down, Would the
resistor help with the current. The regulator gets a little hot if you
leave it on too long.
Mark
From: Dennie Bishop [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=T09SNQDLRA6ieFKdILkKwwKxhpyGT-ZBnbyyv1PO3UPF_dptLFsx8MoMbEj8DVjGfpZtvqf6yiQJs2qos19Q0Hr2e74n2Iritg]dbishop@e...[/url
Sent: Tuesday, February 12, 2002 8:20 PM
Subject: RE: [noparse][[/noparse]basicstamps] lcd backlight
AAAAAAYYYYYYYY. Turn it off! You must use a current limiting resistor in
From: Alejandro Vazquez [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Cq1evphu1R64JcpcqL5xk54xtdB_T8dOx4NbXwOpjsvhVFVCabTXWRC5cXPu_Jk5KLL5Uz2kTUZC5Ys]alexvazquez@y...[/url
Thank you very much
Alex
> HTH
> David
> "Seattle Robotics"
> character
> > LCD.
> > Thanks
> > Alex
> > Do You Yahoo!?
> ignored.
Do You Yahoo!?
I echo Mark's comments, a diode helped a bit. As for my regulator, it's
great for boiling an egg... and still hanging in there..
Tony
Sent: Wednesday, February 13, 2002 1:44 PM
> Do you have to do this on all of them? I know mine was almost 200mA with
it
the
> Mark
> From: Dennie Bishop [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=cE0-JiFwMpof-oQx2IUMZyFisaJp4JIlR23tzQXMKdNVNLkMRvvmZ5aSj7sCPlW0kpwYiWBTpusgxfD6OVDkSqAUM8eg7ILGgF-vgg]dbishop@e...[/url
> From: Alejandro Vazquez [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=6nPc7Sss0lsoR2UqD_RL8M6b9A4_2P3zuD3UCXPIAkP5D0Z-gEIJN1xYOobbKyCztkTEkAL43WhZp-XfFvjFzA]alexvazquez@y...[/url
> Thank you very much
> Alex
> > HTH
> > David
> > "Seattle Robotics"
> > character
> > > LCD.
> > > Thanks
> > > Alex
> > > Do You Yahoo!?
> > ignored.
> Do You Yahoo!?
