How to get DS1302 time & date in ASCII toscratch pad on...
In a message dated 2/12/02 7:36:05 PM Central Standard Time,
chris01@t... writes:
> I am leaning toward never using a ds1302 again. Too much ag with crystals. I
> purchased a few of the 'high-priced' crystals from Parallax thinking they'd
> do better than the $.05 parts I already had. */Not so, still a less than
> 100% yield - any thoughts on this Jon?/* Next I'll probably just use either
> the 4060 method, or a PIC or TI MSP430 & crystal. I did have plans for the
> trickle charge feature though.....Hmmmm....
> What's the latest consensus on RTC's for use with Stamps? Perhaps a
I've never used enough 1302s to see the problem -- and several of the ones
that I own have the crystals carefully soldered to them. Keeps the little
buggars from getting lost.
Since I tend to use the BS2p, the PCF8583 is my prefered RTC. It uses a
crystal too ... so maybe it's no better a choice.
-- Jon Williams
-- Parallax
-- Jon Williams
-- Parallax
good. I get my 1302's and the correct crystals from RTN Australia. In the
application notes from dallas there is some information regarding screening
out noise that may be worth looking at, mainly by running a ring around the
crystal and the 2 relevant pins, and draining it to 0 volts, plus keeping
the crystal as close as possible to the 1302 pins.
Chris
Sent: Wednesday, February 13, 2002 9:56 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: How to get DS1302 time & date in ASCII
toscratch pad on...
crystals. I
they'd
either
the
> -- Jon Williams
> -- Parallax
