How do I time processor events?
Tony-
Plans for building a timer for your Stamp and sample programs are
shown on my site as indicated in Reg's email. This is a reasonably
versatile timer with good (1 microsecond) resolution. If you don't
need that much precision, one of the other suggested solutions may
better suit your purposes. The timer chip also has a built in
HD44780-compatible LCD interface, so you get a timer and an LCD
driver without using up a lot of Stamp I/O pins.
If you don't have the means or desire to program your own SX18 I can
send you a programmed chip and oscillator--please contact me
off-list if interested.
Steve
On 13 Feb 02 at 9:37, Reginald Neale wrote:
> >Hi how do I get these timing chips from Steve Parkis, and about how much are
> >they? I see how the second Stamp could work, but if there is a cheaper way
> >then that would be better.
> go to http://home.earthlink.net/~parkiss/
Steve
code. I've done this several times, including one commercial application
that required reasonably tight timing.
You'll need an extra output pin. Connect this pin to a second Stamp. Just
before the test section you make this pin go high. At the end of the test
you make that pin go low. The second Stamp has a program running that is
using PULSIN to measure the width of the test pulse. It's easy and effective.
-- Jon Williams
-- Parallax
In a message dated 2/12/02 9:53:36 PM Central Standard Time,
tonys@o... writes:
> Hi I'm trying to time how long it takes to run a certain group of
> operations. It seems simple, I think its the 555 chip that can do this but
> I'm not sure how it can work the way I need it to. I need a chip thats
> counts up an integer by itself, so it won't bog down the processor, which is
> the thing I'm timing, so the processor can't be counting.
> For example, I need to time how long it takes to read the thermometer 100x,
> the pseudo-code would look something like this, assuming there is such thing
> as a chip that just counts up as fast as it can:
> 1) Reset "timing" chip to zero
> 2) Set "timing" chip to start counting up
> 3) Get the thermometer value 100x, timer is counting up by itself while this
> is happening
> 4) Stop the "timing" chip and get an 16-bit integer value in microseconds
> (or faster)
> If you can give some sample code or how to hook up the 555 chip to do this,
> I would very much appreciate it.
> Thanks for any help,
> Tony
is happening
(or faster)
Tony
stamps by offloading time/pulse measurements. Prices are very
reasonable.
Reg
>Depending on the length of your events, you can use a second Stamp to time
>-- Jon Williams
>-- Parallax
>tonys@o... writes:
>processor, which is
>such thing
>while this
> > is happening
> > (or faster)
> > Tony
>from the same email address that you subscribed. Text in the
>Subject and Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Have a look at:
http://www.emesystems.com/BS2speed.htm
(which has a link to http://www.phanderson.com/timer_1_2.html)
Stephan
> From: Reginald Neale [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ZooIb75mBy4D9vhSzuhfdSreUAivthcmSx3NYREDLj7ynID8L7b6s0LW_ohOZUBOrdRMbJGcLiUvd5-Wh3NcRA]rneale@m...[/url
> Sent: Wednesday, February 13, 2002 2:13 AM
> Subject: Re: [noparse][[/noparse]basicstamps] How do I time processor events?
> Steve Parkis has designed and made available chips to work with
> reasonable.
> Reg
> effective.
>> -- Jon Williams
>> -- Parallax
>> tonys@o... writes:
> but
>> processor, which is
> 100x,
>> such thing
>> while this
>>> is happening
> microseconds
>>> (or faster)
> this,
>>> Tony
what you want.
One thing I've done in the past where I need a cheap time is to use a
large RC network (can't get much cheaper than that). The Stamp
discharges the cap, does its thing, and then uses RCTime to measure how
long it takes the RC to cross threshold. You could compute the time
required to do the operations by computing Top=Ttotal-Trc where you
could determine Ttotal mathematically or experimentally. The
disadvantage is you always require Ttotal time to go through the loop.
If the operation is short, you will still require a constant amount of
time (and Ttotal>Top+overhead for the longest possible Top).
This is a really good technique where you want to time out. For example,
one of the projects of the month awhile back was a combination lock. If
you kept pressing buttons, it wouldn't time out. But if you didn't press
a button for a few seconds, the lock would reset to its original state.
Good luck!
Al Williams
AWC
* Control 8 servos at once
http://www.al-williams.com/awce/pak8.htm
> From: Tony Suriyathep [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rvWicQLMKt3aBrGPmsEFVQGnZYBSJqz_cfKh_6F1UmIDTqkG3Zvrlke3jZsONf7TC-nnkxIsyxjJYTVr]tonys@o...[/url
> Sent: Wednesday, February 13, 2002 12:54 AM
> Subject: [noparse][[/noparse]basicstamps] How do I time processor events?
> group of operations. It seems simple, I think its the 555
> chip that can do this but I'm not sure how it can work the
> way I need it to. I need a chip thats counts up an integer
> by itself, so it won't bog down the processor, which is the
> thermometer 100x, the pseudo-code would look something like
> this, assuming there is such thing as a chip that just counts
> itself while this is happening
> microseconds (or faster)
> chip to do this, I would very much appreciate it.
> Tony
that life without one is like life without a decent set of hex
wrenches. And as a result of EBay, you can buy a decent used scope
for less than the cost of a pair of stamps.
Toggle a pin at the beginning and end of a loop. Measure time
interval.
this but
thats
which is
thermometer 100x,
such thing
while this
> is happening
microseconds
> (or faster)
do this,
> Tony
the TLC551 which draws much less power) and an RC network for
the kind of timing you're looking to do. I let a capacitor build up a
charge on the control pin of the 551, and the pulse widths output from
the 551 are then a function of how long it's been since the cap was last
dumped. The nice thing about this method is that you can manipulate
the nominal pulse widths output by the 551 to optimize your program
speed and desired timing resolution. In other words, I can measure
time on the order of seconds with a quick pulsin command. I think the
551 is a buck or so.
Clark Hughes
From: Reginald Neale [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=ncJdH_px3NCq-QGMgKU1rmJd14uyVgdOg2Yn5SgSiIHf5ovdCtYqKUb_OyahPmOnBsijLUzpJMojrRrZveyWWw]rneale@m...[/url
reasonable.
Reg
effective.
>-- Jon Williams
>-- Parallax
>tonys@o... writes:
but
>processor, which is
100x,
>such thing
>while this
> > is happening
microseconds
> > (or faster)
this,
> > Tony
That's a neat idea, to subtract the RCtime accumulated during the
test routine from an independently measured total time
Say a 0.1 uf capacitor connected from +5 to P0, and a 909kohm
resistor from P0 to ground, which will allow measurement of test
routines up to ~0.12 second.
Ttest var word
Ttotal var word
total: ' find total time, without the test routine
high 0
pause 20
rctime 0,1,Ttotal ' should be around 0.12 second,
' 60000 counts with R=909k, C=0.1uf
test:
high 0 ' discharge capacitor
pause 20
input 0 ' allow capacitor to start charging
' **** do the special test routine here ****
rctime 0,1,Ttest ' this time will be shorter than Ttotal
debug dec Ttotal, tab, dec Ttest,cr
end
Turning P0 to an input prior to entering the test routine allows the
RCcharging cycle to start early, so when the program does finally hit
the RCtime command, the time it measures will be shorter than Ttotal.
I'm confused right now before morning coffee about whether you can
simply subtract Ttest from Ttotal to get the time taken by the test
routine, or whether you have to do some more math with markers on the
exponential discharge curve
1.3 = 5*exp(-T/(R*C)) ' 1.3 volt Stamp threshold, 5 volt Vdd
It would certainly be linear if the capacitor were charged by a stiff
current source instead of a resistor.
-- Tracy
