serial communications with BS2
I'm attempting to intercept the serial data that comes back to the
BS2 debug window that's supported by the Basic stamp editor (v1.3).
I'm using the MSComm ActiveX control in VB6 pro.
The BS2 debug window receives data with settings of 9600 baud, parity
none, data bits 8. When I configure the MSComm control with these
same parameters, I see no input. However, when I slow the baud rate
down to 1200 baud (on the control), I can detect data transmissions
at the same frequency as the debug window. However, the data received
is bogus and the MSComm control detects an input buffer length of 0
bytes.
Is it necessary to enable some sort of handshaking in order to
establish receive-only communications with the BS2? (Any tips or
examples appreciated!)
Thanks!
bytes.
Thanks!
used a VB6 program I wrote. I cannot remember specifics as it was about
1yr ago, sorry. Check your parameters again in the VB program. Sounds
like you have something configured incorrectly.
Brian
If you can see the data in the terminal windows or in Hypterterminal then
the data is there!
Tony Wells
Sent: Monday, February 11, 2002 2:17 AM
Subject: [noparse][[/noparse]basicstamps] serial communications with BS2
> bytes.
> Thanks!
options as well but with no benefit.)
Any thoughts re. a logical way to troubleshoot using the control?
Thanks!
--- In basicstamps@y..., <tony.wells@a...> wrote:
> I've come across this before. Set the control for no handshaking.
Hypterterminal then
> the data is there!
> Regards,
> Tony Wells
> From: "donnmoidaho" <donnmo@l...>
> To: <basicstamps@y...>
(v1.3).
parity
rate
transmissions
received
0
> > bytes.
> > Thanks!
> > basicstamps-unsubscribe@y...
Subject and
combinations but with no success.
Do you remember anything unique about the behaviour of the control in
the program that you'd written? (Were you receiving data through the
OnComm event?) Any hints or tips re. a logical or methodical approach
to debugging appreciated.
Thanks!
--- In basicstamps@y..., Brian Gracia <bgracia@t...> wrote:
> It is not necessary to setup any handshaking. I did this a while
back and
about
Sounds
> Brian
/questions diagnostics which I would do when interfacing any PC to a device.
1. Does the program definately output data to the stamp terminal window?
2. Can you see the same output in Hyperterminal?
3. If you unplug the cable can you still see data coming out of the stamp on
the TX pin?
If the answer to all three questions is yes, then it must be the
control/your program. If so, can you let us have sight of your VB code - I
might be able to spot something.
Tony Wells
Sent: Monday, February 11, 2002 7:15 AM
Subject: [noparse][[/noparse]basicstamps] Re: serial communications with BS2
> I've checked the VB parameters and attempted various permutations and
> Thanks!
> back and
> about
> Sounds
> > Brian
and
in
approach
Try deleting the communication control off of the form and putting a
"fresh" copy on with the parameters set to no handshaking. I've
written several VB6 apps with serial port stuff and this cured a
problem I had with one of them.
Good luck,
Tim
documentation says that it applies only to input, but it also specifies what
may be applied to output. You need this set to 1 for binary or 0 for text.
Chris
bytes.
Thanks!
