BS2 Beginner Problems
Hello, I am sure that I am just over looking something. I have 2
modified servos, sepaerate power supplies with the ground tied
together and I am trying to make the button comand work. I would like
to make the motors reverse when a switch is pressed. If I run the
code without power to the servos it apears to work (I have inserted
debug statments and I can see the messages properly) However when I
try the same code with power to the servos, the switch does not cause
it to branch. Any help is
appreciated. Please let me know what other information I should
supply. Thank you.
You can email me direct at jrknight@t...
Joe
supply. Thank you.
Joe
