BS2sx to BS2 Program sizes
What is the easiest way for me to tell if a program written for the
BS2SX will fit (program size) into a BS2?
When i show the memory map, its the same now matter which stamp I
select.
Jody
select.
Jody
jody.gallant@s... writes:
> select.
Use the Memory Map feature of the Stamp Compiler. This will only apply if
your BS2sx program is in one bank, since that is all that is available in the
BS2.
-- Jon Williams
-- Parallax
> In a message dated 2/9/02 5:44:04 AM Central Standard Time,
the
> > select.
apply if
available in the
> BS2.
> -- Jon Williams
> -- Parallax
So basically what you are saying, is a BS2SX is the same as a BS2,
but with multiple similar sized memory areas, and as long as my
program fits into 1 of these, then it will work on a BS2?
thanks
Jody
The BS2 has one 2K program slot; the BS2sx has eight 2K program slots. If
your BS2sx program will fit into one 2K slot and does not use the PUT and GET
keywords, it will run, albeit a little slower, on the BS2. A few
instructions will need updates to accommodate the processor speed change.
-- Jon Williams
-- Parallax
