BS2 OEM newbie help
Hi all,
This might be asked at least 1000 times in the past, but I couldn't
find any reference.
I have built BS2 OEM with PIC16C57-XT/P and all the parts as per BOM.
The soldering has been checked over and over.... However, in Basic
Stamp editor 1.3 under Identify says LoopBack OK and Echo OK. But the
STamp can not be found.
The setup is as follwing: Win2000 pro, Serial cable male-female
connected at Com1 and BS2, VDD confirmed at 4.99V.
What am I missing? Any input more than welcome.
John
find any reference.
John
to do this
but I don't think I was getting the Echo test to pass.
On 9 Feb 2002 at 9:06, basicstamps@yahoogroups.com wrote:
> I have built BS2 OEM with PIC16C57-XT/P and all the parts as per BOM. The
> soldering has been checked over and over.... However, in Basic Stamp
> editor 1.3 under Identify says LoopBack OK and Echo OK. But the STamp can
> not be found.
> Thanks
Thanks for the reply. Being a newbie is hard and emba... I'll stop
here. My problem was that I used all parts from the market, and the
PIC is not loaded with Parallax software....
John
--- In basicstamps@y..., "Mike DeMetz" <miked@e...> wrote:
> Try setting the RX FIFO for your comm port to its lowest setting or
off. I had to do this
BOM. The
Stamp
STamp can
> > not be found.
> > Thanks
