bit''s from slot to slot
In order for this to work you must define the variables in one program (slot)
EXACTLY as and _in_the_same_order_ as in your other program (slot). The
other thing you can do is use PUT and GET with the shared scratchpad memory.
-- Jon Williams
-- Parallax
In a message dated 2/8/02 7:41:35 AM Central Standard Time,
hschwenk@y... writes:
> Hi all,
> > I use Stamp2P 40
> > My programs did not work together in the different
> program slots.......
> > reducing the code step by step to:
> > In slot 0:
> > '{$STAMP BS2p,test1}
> > 'flagxy var bit
> > flag var bit
> > testloop var byte
> > flag=1
> > testloop=testloop+1
> > Debug "test= ",dec testloop," flag= ",dec flag,cr
> > pause 2000
> > run 1
> > In slot 1:
> > '{$STAMP BS2p}
> > flag var bit
> > testloop var byte
> > Debug "TEST1= ",dec testloop," flag= ",dec flag,cr
> > pause 2000
> > run 0
> > if the "flagxy var bit " is deactivated,
> > in my debug "TEST1" the flag=1 like I expected
> > But now:
> > if I activate flacxy var bit
> > in my debug "TEST1" the flag=0 I DID NOT ASPECT
> THIS
> > the "counting" of the "testloop" is always to see
> right
> > Do I do or understand something wrong ?
> > Or is it not allowed to "transfer" Information from
> slot0 to the
> > slot1 via bit's?
> > Is there any documentation (which I did not see)?
> > Or is it a bug?
> > some ideas or information's would be helpful
> > Thanks Heinz
-- Jon Williams
-- Parallax
> Hi all,
> > I use Stamp2P 40
> > In slot 0:
> > 'flagxy var bit
> > flag var bit
> > testloop var byte
> > flag=1
> > testloop=testloop+1
> > pause 2000
> > run 1
> > In slot 1:
> > '{$STAMP BS2p}
> > flag var bit
> > testloop var byte
> > pause 2000
> > run 0
> > But now:
> THIS
> right
> slot0 to the
> > slot1 via bit's?
> > Or is it a bug?
> > Thanks Heinz
