Polaroid 6500 Sensors and more!
Hello,
I have hooked up the 6500 ranging sensors, but, I am trying to get
them to operate to sense around the 6" range. Unfortuneately, it
only senses things past 17-18"... does anyone know how i can get this
to work around the 6" range? Please.. I really need info on this!
Its very important that I get this to work, otherwise, my term
project is useless!
Another thing, how can I do error checking if I'm sending data via an
RF transceiver? I have a computer and a robot and each have a
transceiver. However, there is some error in the transfer, and I
need to know how to do error checking, if possible. The computer is
running a C program.
Thanks!
Debu
project is useless!
Thanks!
Debu
I used a bunch of 6500 sensors and I couldn't get them to work that
far. You need to play around with the BINH and BLNK pins to
adjust for close and small objects.
Sent: Friday, February 08, 2002 1:16 AM
Subject: [noparse][[/noparse]basicstamps] Polaroid 6500 Sensors and more!
> Hello,
> project is useless!
> Thanks!
> Debu
wrote:
check out www.acroname.com they have info on the 6500,
as well as other types.. and sample code to use with
many types of microcontrollers...
> Hi,
> them to work that
> pins to
> From: "debu_sen_22" <debu_sen_22@y...>
> more!
> > Hello,
> am trying to get
> Unfortuneately, it
> how i can get this
> need info on this!
> otherwise, my term
> > project is useless!
> sending data via an
> each have a
> transfer, and I
> > Thanks!
> > Debu
> Text in the Subject and Body of the message will be
> ignored.
__________________________________________________
Do You Yahoo!?
Send FREE Valentine eCards with Yahoo! Greetings!
http://greetings.yahoo.com
These have a range of 3cm to 3 meters. They cost $25 available from
www.acroname.com
I have used them, and found them to be a highly reliable sensor. Acroname
also has programming examples for the BS2.
I wrote an article on these for N&V it will be out in the april issue.
Very respectfully, your obedient servant.
Kerry
Admin@M...
WWW server hosting [url=Http://mntnweb.com]Http://mntnweb.com[/url]
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1132
Thank you everyone for your feedback, however, we have purchased the
6500 sensors, and our budget for our design project will not let us
change to a new type...
--- In basicstamps@y..., Kerry Barlow <admin@m...> wrote:
> You could just not use the 6500 and instead use a devontech srf04
sensor.
> www.acroname.com
Acroname
issue.
> Kerry
> Admin@M...
> Kerry Barlow
> p.o. box 21
> kirkwood ny
> 13795
> 607-775-1132
anything closer that what you have already detected. The sound transmitter
and receiver need a short blanking period after sending the sound pulse to
avoid drowning out the receiver with noise from the transmitted pulse).
Since the device has one big transducer, you have to let it settle down
longer, which means you can't get ranges down too close.
The Devantech units, has two transducers, one for transmit and one for
receive, and the units are smaller, so they have less blanking or settling
time between pulses. So you can get down to a couple of inches or less even
in some cases. But they don't go much beyond about 68-72 inches in range.
If your using this for a maze robot, your pretty much SOL, as the two side
walls are too close together for the size mazes they use.
A.) One suggestion is to add the Devantech range finders to your devices to
suppliment the Polaroid ones. Then the Polariod would work for longer ranges
and the Deventech for short ranges.
B.) Another suggestion is to maybe try a crossfiring method. Where you would
move the Polaroid unit father back on your device, maybe at the rear
pointing forward. Then you might be able to get it closer as you can
subtract the length of your device from the ranges being detected. But then
this idea may not help you if your design is fixed.
C.)You could also use a IR range/object detector like the Sharp GP2D02
(www.acroname.com) for close range distance measuring as well, to suppliment
the Polaroid range finder. Depending on the IR devices chosen, this can be
anything from simple object detection to the more precise Devantech units,
with costs varying from a few dollars up to $21 for one of the Devantech
units.
D.) A final thought might be to use an object opposite from the one coming
in too close. For example two walls in a hallway. You can measure the
distance to the walls front and back. This gives you the total length of the
hallway (or width as well maybe), then as you approach the far wall, you can
use the opposite wall's range to tell you how close your coming, when the
near wall goes under the minimum range detected. A method like this should
let you get down to 1/2" or less. Thus if the walls are say 20 feet apart,
the rear near wall is now in the garbage range, the front wall is measured
at 19 feet. As you approach the front wall, the rear wall becomes
measurable, then as you get too close the front wall becomes unmeasurable,
but the rear wall can be measured now. You can subtract the length of your
device to get a more accurate distance from the front wall.
From: debu_sen_22 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=745bFrBYt5SAT-OKSekyK19SUnRL046qniP4EsAaWp8Tz5ictnjqWrmZ78R8chFGkzI6mlS9wOuOVG7MWQ]debu_sen_22@y...[/url
Sent: Monday, February 11, 2002 11:12 PM
Subject: [noparse][[/noparse]basicstamps] Re: Polaroid 6500 Sensors and more!
Hi
sensor.
> www.acroname.com
Acroname
issue.
> Kerry
> Admin@M...
> Kerry Barlow
> p.o. box 21
> kirkwood ny
> 13795
> 607-775-1132
I don't get it then why does it say that they can detect at a much
lower distance than the 17 inches?
Well, I am discussing it with my group members, and, it doesn't seem
like our budget will let us change to IR sensors. They cost about
$22, and we would require to get 4 of them. Is there anyone out
there who's willing to sell us some cheap cheap GPD02 (Sharp) IR
sensors?
DS
--- In basicstamps@y..., "Earl Bollinger" <earlwbollinger@a...> wrote:
> Unfortunately, Polaroid range detectors, by their nature, can't
detect
transmitter
pulse to
pulse).
down
for
settling
less even
range.
two side
devices to
longer ranges
you would
But then
GP2D02
suppliment
can be
units,
Devantech
> units.
coming
the
length of the
wall, you can
when the
should
apart,
measured
unmeasurable,
of your
> From: debu_sen_22 [noparse][[/noparse]mailto:debu_sen_22@y...]
> To: basicstamps@y...
> Hi
> Thanks
> sensor.
from
> > www.acroname.com
> Acroname
> issue.
> > Kerry
> > Admin@M...
> > Kerry Barlow
> > p.o. box 21
> > kirkwood ny
> > 13795
> > 607-775-1132
> basicstamps-unsubscribe@y...
Subject and
field.
In other words when the sensor reads 18 inches or more the focus is set the
same as the reading, but when the sensor reads minimum the focus actually
gets set to 12 inches but with the tight aperture's depth of field objects
between 6 and 24 inches are somewhat focused in.
KF4HAZ - Lonnie
> Hey...thanks for the info.
> sensors?
> Thanks
> DS
require, be aware however that it fails in detecting very narrow objects.
If you need to detect a wall, or large object, no problem. If you are
trying to detect something narrow such as a chair leg in circumfrance, then
the Sharp sensors will miss detection at times. You may want to look at the
specs on the Devontech SRF04 sensor.
http://www.acroname.com/robotics/parts/R93-SRF04.html
I am affiliated in no way with them, I just however have used both the Sharp
and the Devontech. In my application for robotics, I was always finding the
Sharp allowing my robot to run into chair legs. Doh doh doh.
I understand that your budget has you limited now. Good luck to you!
Have you thought of the polaroid for longer range, and cheap $2 IR sensors
for close in range detection? The ones that Parallax sells I was thinking
of. I forgot what brand they are off hand, Phillips?
-kerry
At 09:25 AM 2/12/02 -0600, you wrote:
>Polaroid's claim is based on using tight aperture which improves depth of
>field.
>KF4HAZ - Lonnie
>> sensors?
>> Thanks
>> DS
Kerry
Admin@M...
Kerry Barlow
p.o. box 21
kirkwood ny
13795
607-775-1132
upright on the bench by scanning back and forth and centering on the
positions where the outer edge of the beam detects a closer object.
> The sharp GPD02 sensor is a very good sensor, and has short range as you
then
the
Sharp
the
good as the older original ones.
At that time no one had mentioned anything about apertures and how to set
them.
You can goto www.parallaxinc.com and check out the IR transmitter and the IR
detector devices, like they use in the Basic Stamps Robotics manual
experiments. Check out the robotics manual. I think the detector cost $5.50
and the transmitter cost $2.50. Basically, you output a 38,000 hertz pulse
using the FREQOUT function, then you look on the detector with a FREQIN
function to see if you pick up a reflection. You can get fancy and use a 555
timer to do the FREQ out part too or some other method. Although I haven't
tried it you could use the Radio Shack IR transmitter and detector
phototransistors as well. Radio shack had these going for about $2.00 as a
matched set. But I haven't tried them yet to see how they work, so I don't
know. This low cost IR detector method works quite well, but you don't get
accurate ranging that way, you just get a object is detected.
From: debu_sen_22 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=CQy8n3TtWtAiMhh8Xb5bqIcVtU-ElkT1MAM7pQeod_opctfkdmKzqp8ADkhvT-NU5ljEs-8lmuuIfqE-BA]debu_sen_22@y...[/url
Sent: Tuesday, February 12, 2002 8:58 AM
sensors?
DS
detect
transmitter
pulse to
pulse).
down
for
settling
less even
range.
two side
devices to
longer ranges
you would
But then
GP2D02
suppliment
can be
units,
Devantech
> units.
coming
the
length of the
wall, you can
when the
should
apart,
measured
unmeasurable,
of your
> Hi
> Thanks
> sensor.
from
> > www.acroname.com
> Acroname
> issue.
> > Kerry
> > Admin@M...
> > Kerry Barlow
> > p.o. box 21
> > kirkwood ny
> > 13795
> > 607-775-1132
Subject and
section on sensors.. To include two or three types of
the sharp ir ranger you are speaking of. As well as
polaroid rangers, ans devanchi sonar rangers.. wich I
think are much better....
--- Earl Bollinger <earlwbollinger@a...> wrote:
> The best I got was around 2 feet minimum, maybe the
> newer ones aren't as
> them.
> Robotics manual
> detected.
> From: debu_sen_22 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1mHL8YD0eFXy-fA0Oe_FCTCE8A72hOgjmZatbAeX-mn60vA-4Nc6VREPKa97rYwqQocvirUtG3oyCVM]debu_sen_22@y...[/url
> more!
> detect at a much
> it doesn't seem
> They cost about
> there anyone out
> GPD02 (Sharp) IR
> sensors?
> Thanks
> DS
> nature, can't
> detect
> detected. The sound
> transmitter
> sending the sound
> pulse to
> the transmitted
> pulse).
> to let it settle
> down
> close.
> transmit and one
> for
> less blanking or
> settling
> couple of inches or
> less even
> 68-72 inches in
> range.
> much SOL, as the
> two side
> they use.
> finders to your
> devices to
> would work for
> longer ranges
> you would
> maybe at the rear
> closer as you can
> being detected.
> But then
> fixed.
> like the Sharp
> GP2D02
> suppliment
> can be
> precise Devantech
> units,
> for one of the
> Devantech
> > units.
> coming
> You can measure
> the
> you the total
> length of the
> approach the far
> wall, you can
> close your coming,
> when the
> method like this
> should
> apart,
> the front wall is
> measured
> rear wall becomes
> wall becomes
> unmeasurable,
> subtract the length
> of your
> front wall.
> and more!
> > Hi
> have purchased the
> > Thanks
> a devontech srf04
> > sensor.
> $25 available
> from
> > > www.acroname.com
> reliable
=== message truncated ===
Do You Yahoo!?
