Voltage Controlled Oscillators?
This is off topic, but I thought I'd pick your great barins anyway, and it is
applicable to data transmissions..soo...
In our labs on campus we used the LM566 Voltage controlled oscillator. A great
chip for converting a voltage into a modulated frequency (FM). This chip can
not longer be found for sale. Anyone have any good replacements? It seems this
is such a fundemental chip, there would be a good replacement for it, but I am
having trouble finding one.
Any ideas?
Martin Hebel
Southern Illinois University
Electronic Systems Technology
Any ideas?
Martin Hebel
http://www.hoohahrecords.com/resfreq/datasheets/nte994m.pdf
Also see:
Leroy
great chip for converting a voltage into a modulated frequency (FM). This chip
can not longer be found for sale. Anyone have any good replacements? It seems
this is such a fundemental chip, there would be a good replacement for it, but I
am having trouble finding one.
> Any ideas?
> Thanks,
> Martin Hebel
>is applicable to data transmissions..soo...
>chip can not longer be found for sale. Anyone have any good replacements?
Yep - use the LM567 or NE567 or NJ567 - available from many suppliers. The
566 is just the VCO portion of the 567. Might have different pinout but
should otherwise work exactly the same.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
We also use the 567 tone decoder, but an important aspect is simply
the voltage to oscillator conversion. The 567 is actually the other
end, a specialized Phase Locked Loop.
--- In basicstamps@y..., Dwayne Reid <dwayner@p...> wrote:
anyway, and it
oscillator. A
(FM). This
replacements?
suppliers. The
pinout but
> dwayne
Not Digikey, Jameco, JDR....
Thanks anyway,
-Martin
--- In basicstamps@y..., Leroy Hall <leroy@f...> wrote:
> Would this work?
> Also see:
> Leroy
anyway, and it is applicable to data transmissions..soo...
oscillator. A great chip for converting a voltage into a modulated
frequency (FM). This chip can not longer be found for sale. Anyone
have any good replacements? It seems this is such a fundemental
chip, there would be a good replacement for it, but I am having
> > Any ideas?
> > Thanks,
> > Martin Hebel
> > basicstamps-unsubscribe@y...
Subject and Body of the message will be ignored.
Leroy
selmaware wrote:
> Leroy, it sure would!...... If I can find anyplace that sells them!
> Thanks anyway,
> -Martin
> > Would this work?
> > Also see:
> > Leroy
> > > Any ideas?
> > > Thanks,
> > > Martin Hebel
>Thanks Dwayne,
I'd agree with you but the Signetics data book specifically states that the
566 is simply the VCO section of the 567. As a result of reading that
(years ago), I quit using 566s in the products that used them and started
using the same 567s we also use (fewer parts to inventory). In view of the
fact that 566s are no longer available and 567s should still be around for
quite some time to come, I'm glad we did.
I also use the VCO section of the 4046 PLL in several products - its even
easier to use than the 566 or 567 because you can set both the upper and
lower frequency limits with 2 external resistors. But its in a larger package.
I can dig up the original Signetics data book if you would like a fax of
the data sheet. As far as I know, the whole 56x series of PLLs and VCOs
were designed by Signetics (long before they got swallowed by Phillips).
dwayne
