Capacitave Humidity Sensor
Hi All,
I have a Rotronics Capacitive humidity sensor I need to be able to read for
a stamp application. The range on the sensor goes from 200pF to 300pF. I
tried to set up an RC circuit to do so, but soon realized this was nearly
impossible. The ideal resistance is 300Mohms!!! Since this isn't feasible, I
used 30Mohms to test with. The times were all over the place, unusable. Does
anyone know of adifferent way to get th capacitance, preferably without
changing the hardware much, since I have boards burned [noparse];)[/noparse] Thanx
Nick
_________________________________________________________
Do You Yahoo!?
Get your free @yahoo.com address at http://mail.yahoo.com
Nick
Do You Yahoo!?
lightclb@y... writes:
Try inserting it into an oscillator circuit and reading oscillator the output
using PULSIN.
-- Jon Williams
-- Parallax
>Hi All,
>Nick
Don't ask me for circuit or interface details, but some commercial polymer
(capacitance) humidity sensors I have, with readout (meaning they were a
turnkey solution), use a LTC-1043CS interface chip.
See http://www.linear.com/pdf/lt1043cs.pdf for a 2-page PDF data
sheet. Hope it helps.
Jim H
Paul
> Hi All,
> Nick
> Do You Yahoo!?
