BS2 &ADXL202 Accelerometer
Has anyone used the Analog Device ADXL202
Accelerometer with the BS2 as a tilt sensor? I saw
some information on the AD website about using the ADX
with the BS2 and wondered if anybody tried it. I was
looking for an inexpensive tilt sensor for a robotics
application.
Brian McMillion
__________________________________________________
Do You Yahoo!?
Great stuff seeking new owners in Yahoo! Auctions!
http://auctions.yahoo.com
application.
Brian McMillion
Do You Yahoo!?
>From: Brian McMillion <briank77479@y...>
>Reply-To: basicstamps@yahoogroups.com
>Subject: [noparse][[/noparse]basicstamps] BS2 &ADXL202 Accelerometer
>Date: Sat, 2 Feb 2002 15:22:26 -0800 (PST)
>application.
>Thanks
>Brian McMillion
>Do You Yahoo!?
>from the same email address that you subscribed. Text in the Subject and
>Body of the message will be ignored.
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
_________________________________________________________________
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
easy to use. Analog Devices has a Basic Stamp technical note at
http://www.analog.com/library/applicationNotes/mems/StampXL202.pdf
that has lots of good info. I would recommend getting the ADXL202EB
evaluation board that has built in capacitors and is on a small DIP
board with five .1 inch pins.
Ed
--- In basicstamps@y..., ". ." <brandaris400@h...> wrote:
> http://www.basicx.com/appnotes/bx-24appnotes.htm
> >Reply-To: basicstamps@y...
> >application.
> >Thanks
> >Brian McMillion
> >Do You Yahoo!?
> > basicstamps-unsubscribe@y...
Subject and
prototyping with
surface mount components, I suggest you either go with the eval board that
another
poster mentioned, or you have a board fabricate what you need to mount the
components.
I'm having ExpressPCB do mine. Soldering components directly to the chip is
possible
(I did it on my first prototypes), but not optimal.
Clark Hughes
> application.
> Thanks
> Brian McMillion
> Do You Yahoo!?
