Comparing
I have variable made up of three individual inputs and was wondering
if there was a way that it could be compaired to itself in case its
state hasn't changed since the previous loop. If it hasen't I would
like it to continue it's loop without changing the status of the
outputs. If the variable has changed then proceed with apropriate
output.
output.
Below is a farily classic method.
Tony Wells
0
Current var byte 'current input value
Previous var byte 'previous input value
START:
gosub GatherDataIntoCurrent
Previous= -Current 'this forces output first time
LOOP:
if Current<>Previous then DoOutPut
gosub DataIntoCurrent
goto LOOP
DoOutPut:
Previous=Current
gosub SetOutputState
goto LOOP
Sent: Tuesday, January 29, 2002 2:03 AM
Subject: [noparse][[/noparse]basicstamps] Comparing
> output.
