Ground plane
Hello,
I have a board with a ground plane and before holding the BS2 and other IC's
in sockets I tested the board power.
I have connected the o/p of the transformer ( 220V/9V ) to the board power
supply and the dc voltage was OK but there is something I have found , when
I touch the ground area I feel a little vibration in my finger,it seems like
a kind of ac source.This disappear when I reverse the main terminal.Any
explanation would be appreciated.
Thank You
Mohamed Refky
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com/intl.asp.
Thank You
Mohamed Refky
disconnect the 220 VAC, BEFORE YOU GET KILLED!! While you were feeling
that "tingle" if had touched a metal object or stood on a wet concrete
floor, you would be speaking to the man upstairs.
regards,
Leroy
Mohamed REFKY wrote:
> Hello,
> Thank You
> Mohamed Refky
Sent: January 26, 2002 9:09 AM
Subject: Re: [noparse][[/noparse]basicstamps] Ground plane
Could just be transformer hum! Use a scope.
Sent: January 26, 2002 12:16 PM
Subject: RE: [noparse][[/noparse]basicstamps] Ground plane
Mohamed, are you saying that you have a transformer w/ a 220V
primary, and a
9V secondary winding directly connected to a logic-level supply
on your
board? Is the secondary center-tapped, and the ground plane
common to the
tap? I guess without knowing your power supply configuration from
the AC
line to the final DC output, there are a number of possible
things going on.
WIthout knowing what caps you are using, where the Transformer
is, etc, it
would be hard to do more than speculate.
Chris
Hello,
other IC's
board power
found , when
seems like
terminal.Any
Thank You
Mohamed Refky
Subject and
Subject and Body of the message will be ignored.
9V secondary winding directly connected to a logic-level supply on your
board? Is the secondary center-tapped, and the ground plane common to the
tap? I guess without knowing your power supply configuration from the AC
line to the final DC output, there are a number of possible things going on.
WIthout knowing what caps you are using, where the Transformer is, etc, it
Chris
Hello,
Thank You
Mohamed Refky
The 9V connected to the bridge rectifier ==> 1000uF filter capacitor ==>
7805
The output of the bridge for the BS2 and the 5V for other components.
>From: "Chris Loiacono \(E-mail\)" <chris01@t...>
>Reply-To: basicstamps@yahoogroups.com
>Date: Sat, 26 Jan 2002 12:16:43 -0800
>Mohamed, are you saying that you have a transformer w/ a 220V primary, and
>a
>on.
>Chris
>Hello,
>IC's
>when
>like
>Thank You
>Mohamed Refky
Send and receive Hotmail on your mobile device: http://mobile.msn.com
