BS2 Characteristics Questions — Parallax Forums
edited 2002-01-25 16:25 in General Discussion
I'm using a BS2, Rev. F which has a PIC16C57 Microcontroller.
Question 1. What is the minimum bypass capacitor on Vin, with the
battery about 10 inches away.
Question 2. What are the characteristics of the I/O pins when the
power is off(Vdd=0)? Can I apply +5v to the I/O pins from an
external
source without damage to the 16C57? What is the leakage? I've
looked
at the Microchip Technology 16C57 spec sheets but I can't figure out
which parameter is applicable.
Dave
    edited 2002-01-25 15:14
    Dave there is no single correct answer to that question.
    First off different families of caps have differing characteristics, namely
    internal resistance, which acts as an rc combination.
    Secondly is the question of what you are trying to bypass out of the supply,
    for example a .001uf ceramic disc will keep out most UHF and higher
    interference, but wouldn't help much at keeping 60Hz ripple out.
    In general I use anything from a .1uf to a 1uf monolithic ceramic, even
    though often times there would be no problems if no bypass cap were used at
    all.
    Also note that large value electrolytics while good at keeping 60Hz line
    ripple down are of little help at bypassing RF (Which most of my stuff has
    to deal with, as many of my projects are connected to 2 to 50 watt
    transmitters.)
    In worst case conditions 470uf will keep the 60Hz ripple below a volt or so,
    and a .1uf mono directly across Vin to Vss will block RF.
    To sum it up, you could try not using a bypass cap and if trouble arises
    connect a scope from Vin to Vss and see if you cap identify the Freq. and
    amplitude, If low freq. large cap, high freq small cap.
    Or you could make it a standard practice to always use a small monolithic,
    just to be safe, after all it also helps keep the processors clock and
    switching spikes off the supply where they could cause trouble for other
    parts of the circuit.
    KF4HAZ Lonnie
    > external
    > looked
    > Thanks
    > Dave
    Lonnie,
    Thanks for the advice. I've settled on a 1uF monolithic and the
    circuit seems to work fine.
    Dave
    --- In basicstamps@y..., "FalconWireless Tech Support - KF4HAZ"
    namely
    supply,
    even
    used at
    > all.
    line
    stuff has
    > transmitters.)
    volt or so,
    arises
    Freq. and
    monolithic,
    and
    other
    > KF4HAZ Lonnie
    > > external
    > > looked
    out
    > > Thanks
    > > Dave
