Digital potentiometer — Parallax Forums
edited 2002-09-05 21:36 in General Discussion
Anyone have a listing for such a project?
    edited 2002-01-22 22:38
    I know that such chips are commercially available. Analog devices or
    Dallas semi has them. Don't know if this is the info ou are looking
    for. I haven't used them.
    --- In basicstamps@y..., "theborderlinecrew" <theborderlinecrew@y...>
    edited 2002-01-23 00:36
    There is a chapter in Matt Gilliland's book, the Microprocessor Cookbook, on
    digital pots. It includes code.
    I have used the DS1267 and the DS1804. The 1804 is easier and more intuitive to
    work with, but it takes more code
    to control the wiper. It seems to me the 1267 is faster to respond, but I am
    not able to measure this.
    Differences in specs include, in addition to the resistance element, the number
    of positions on the wiper. A high
    resolution pot like the the 1267 offers 255 increments. The 1804 has 100.
    If you are working on a prototype I understand, from other correspondence on
    this group, you may be able to get
    samples of these chips at the DS site. I think the address is www.dalsemi.com
    What do you want to do with the digital pot?
    Best, Michael
    edited 2002-01-23 00:44
    digital pots.
    nuts and volts did an article on them, ive attached it to this email.
    its fairly simple and straightforward.
    norm
    >From: "diacon1208" <dpotter@d...>
    >Reply-To: basicstamps@yahoogroups.com
    >Subject: [noparse][[/noparse]basicstamps] Re: Digital potentiometer
    >Date: Tue, 22 Jan 2002 22:38:56 -0000
    >Body of the message will be ignored.
    _________________________________________________________________
    MSN Photos is the easiest way to share and print your photos:
    http://photos.msn.com/support/worldwide.aspx
    edited 2002-08-29 19:51
    I have a large DC motor and controller that I want to control from a
    BS2. I really don't want to control the DC motor directly from the
    BS2 and rather use the existing controller.
    On the controller there is a knob with a 5k pot for speed control.
    How can I by-pass that pot?
    Should I measure the voltages across the leads and try to duplicate
    with the stamp?
    I have seen some Digital potentiometers from DigiKey but have no
    clue how they work. Would this do the job?
    Another idea I have is to use the small feedback pot inside a servo
    motor to replace the controller speed control pot - this way I can
    control the speed by controlling the servo. The question is: what
    is the typical value on the servo pots (I have a few "hitec" around).
    Please help!
    edited 2002-08-29 20:35
    Probably the easiest thing to do would indeed be use a servo and attach it
    somehow to the speed control knob. (Gears, belts, what ever). Servos are
    extremely easy to control with a Stamp. The voltage is +5VDC and ground,
    and use pulse out to control the position of the servo. A pulse 1 to 2 MS
    is all that is required repeated 50 times per second with 1.5 ms being
    centered. Piece of cake. Example code is in the Basic Stamp manual or go
    to the Parallax web site under resources and look at Stamp Works experiment
    # 25 and it will tell you all you need to know. SImple stuff..
    MIke B.
    Sent: Thursday, August 29, 2002 11:51 AM
    Subject: [noparse][[/noparse]basicstamps] Digital Potentiometer
    > with the stamp?
    > Please help!
    edited 2002-09-03 17:46
    If your controller is like many I've worked with, the pot just sets a
    voltage for the error amp. With a setup like that, you could easily
    use a DAC on your stamp to act as the voltage from the pot. In most
    cases you can put in a SPDT switch to select either manual or computer
    control with very little modification to the controller. If you do
    choose to use a digital pot, you need to read the spec sheet
    carefully. They don't all have the same range of voltages. Also most
    dig-pots have some resistance even when they are set to zero.
    a
    > with the stamp?
    around).
    > Please help!
    There are all kinds of digital pots....
    > MIke B.
    > From: "brownstamp" <brownstamp@y...>
    > > with the stamp?
    > > Please help!
    Sean T. Lamont, CTO / Chief NetNerd, Abstract Software, Inc. (ServNet)
    Seattle - Bellingham - Vancouver - Portland - Everett - Tacoma - Bremerton
    email: lamont@a... WWW: http://www.serv.net
    "Do not fear mistakes, There Are None" - Miles Davis
