Vibrating String Sensor
Hello all,
I am trying to build a device that records a piano performance as midi
data. I have a switch on each hammer that is triggered by each key, but
this is only on/off data. I built a device that translates this into
midi data, but because no intensity is recorded, the recording is not
very realistic.
I could easily put pickup coils under each of the strings, but how would
you suggest reading these values, and assigning a number between, say, 0
and 15, based on its amplitude? The pickup coils would return an AC
signal, so an analog-digital converter wouldn't work w/o some
modification.
Managing the output off all these will not be a problem. I just want to
build a device that will read a string intensity, and have it be simple
enough to replicate it 60 something times. Any ideas?
Thanks in advance,
Paul Jordan
very realistic.
modification.
Thanks in advance,
Paul Jordan
Sounds like a big job to "midify" a piano keyboard !
I've seen something about that a few years ago. There was a special chip
scanning the status of each input of the 88 switches, and sending note-on,
note-off midi signals, plus the velocity information. I think this is what
you're missing with "normal" switches.
The mechanical part of the switches is made of two bars (like 2 thick copper
wires), connected to 0V and 5V. Each key is fitted with a kind of spring
(like the lower strings of the piano), connected to an input of the circuit.
When the key is not activated, the spring is *just* touching the 0V bar.
When you hit the key, the spring immediately leaves the 0V bar, and touches
the 5V bar a certain time later. This time depends on the attack of the note
played, and is mesured by the electronic circuit, which sends a note-on
message and its velocity.
This is another way to manage the velocity information.
Anyway, how do you read all those switches ? Don't you get any delay problem
when you play a chord ?
Best regards,
Phil.
Sent: Monday, January 21, 2002 11:34 PM
Subject: [noparse][[/noparse]basicstamps] Vibrating String Sensor
> Hello all,
> very realistic.
> modification.
> Thanks in advance,
> Paul Jordan
This actually a project to convert a huge stash of player piano rolls
over to midi files. As it is a player piano, only about 60 keys need to
be monitored; there are only about 60 different notes used on the rolls.
Right now all the switches are hardwired into a gutted Yamaha
synthesizer, so the switches are actually 'playing' on the synth, which
has a midi output. Thus there is on delay, but also no intensity info.
I did have success using one Basic Stamp 2 to scan 16 keys, and send the
midi data for this. It was plenty fast. I would just need 4 stamps for
64 keys. Each would operate on a different midi channel.
However, this has no advantage unless I can capture the intensity data.
I did succeed in building a midi 4-stringed mandolin...
http://users.characterlink.net/jordan/mandolin.htm
I also want to put intensity sensors on this. There are only 4 strings,
so it shouldn't be that hard.
Any ideas on how to read the string vibration intensity anyone? It
shouldn't be that hard...
Paul Jordan
From: Philippe Derenne [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=KcT2hivOatQPXkrFW87oVqinYPy-83PnKrVeXic-Jd2Dl3BnRnRkqsIYPLc9NOoDATtLVEru0nlnJS1J]derennep@s...[/url
Sent: Monday, January 21, 2002 3:05 PM
Subject: Re: [noparse][[/noparse]basicstamps] Vibrating String Sensor
Hi Paul,
note-on,
what
copper
circuit.
touches
note
problem
Best regards,
Phil.
> Hello all,
but
> very realistic.
would
0
> modification.
to
simple
> Thanks in advance,
> Paul Jordan
phototransistors?
painted a roll black, and that fixed that problem. Light still leaked
around the holes. There are more like slits, about a millimeter wide.
The player piano uses a vacuum and bellows arrangement to sense, and
that is pretty foolproof.
Maybe if I get some of those thin rectangle LEDs a d phototransistors I
could do it. The different widths would let different amounts of light
in. That could work. Although then it couldn't record a person, which is
pretty neat to be able to do. Although the person could play on the
synth just as easily...
I would still like to be able to sense the amplitude of the mandolin's 4
strings, however. http://users.characterlink.net/jordan/mandolin.htm
Thanks again.
Paul Jordan
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=zmcnKUfVdS7v-L9mn0tJGP2c8eJtPYkLcG1v04pKnsHPgZyh_ypG6lJd63LPGmPfy3f90huEYLlAb4LFpQ]daweasel@s...[/url
Sent: Monday, January 21, 2002 4:35 PM
Ever thought about reading the rolls directly? Maybe you can do it with
some
phototransistors?
to
rolls.
which
Have you tried just going off the vacuum lines with vacuum switches.
You could set up the vacuum switches in one of two was, depending on the switch.
The first way would be an of on stitch a a given vacuum level.
The second on would be set as a gauge that would go from Atmosphere to the max
vacuum level of the system.
With the second version you should be able to correlate the vacuum reading to a
slot width on the roll.
Just an idea.
Paul Jordan wrote:
> Good idea Rodent, tried that. The paper leaked too much light through. I
> Thanks again.
> Paul Jordan
> From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Hmfg3fNQ6ASX6y1SxzBg_KInp9nzh6wZ75ncaUmmy0j1faa0c1WBoZp0b7RMbUuJSdKKpW_GQj_-]daweasel@s...[/url
> some
> phototransistors?
> to
> rolls.
> which
I hesitate to mention a non-stamp solution, but why reinvent a midi
sampler? Low-cost samplers exist, so one approach is to find a decent
player piano and sample the output directly to midi files. My midi
experience is with a Korg digital grand, but for a real piano
performance experience, I still prefer an acoustic Steinway Model M.
Dennis
From: Paul Jordan [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=olpXrfcc31IwJJ2GwdfBDUClzUZTcLfSHAvQ9o-fll1t2S4JtzEL00TrtIzE3o9L39lUT2sM4ryxAtsgGkEjmnYbSnI8]automations@c...[/url
Sent: Monday, January 21, 2002 2:35 PM
Hello all,
very realistic.
modification.
Thanks in advance,
Paul Jordan
"Sound2Midi" it allows you to convert a recording of audio into Midi. It
might be usefull in this application.
check this link: http://www.hitsquad.com/smm/programs/Sound2MIDI/
Richard
From: Rodent [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=pJ4t38EgNuaSIu9QnP6RmbsfzrrvsxbGfjdImOpGmwD9jvblIW7zzcFp-2ZVr_5JtQ4aMR9OwSI3FQ]daweasel@s...[/url
Sent: Monday, January 21, 2002 7:35 PM
Ever thought about reading the rolls directly? Maybe you can do it with some
phototransistors?
