5V TTL to true rs232
Hi Folks,
I'm trying to interface a Stamp to a serial device on TX and RX which is
*very* fussy about the rs232 voltages. I've tried Max232 to interface, but
the device remains silent. This seems to be becauseMax232 outputs a max of
+/- 8.5v unloaded and the device is loading it down to +/-8v which just
does not seem to be enough to wake up the device.
It works fine however on my PC, which works at +12 and - 12v. I know it is
not my code because I've done lots of subsitution testing to prove the
assertion on the 8v issue.
Does anyone know of a Max 232 type device which works to true 12v or higher?
I'm so desperate I'm willing to work with a +/- 12v PSU to get this working.
Any help would be appreciated.
Tony Wells
Tony Wells
Sorry to hear the MAX232 isn't working. +/- 5V is supposed to do the
trick.
The "traditional" way to go is a 1488 and 1489. One is the line driver
and the other is the line receiver. You provide +/- 12V and you are in
business. Don't mess with the ajustment pins because with some vendors
they never worked correctly anyway. I don't know who still carries
these.
Are you absolutely certain the voltage is the problem? If you hook your
Stamp to the PC does it seem to do what you expect? Something else to
think about: if you are able to talk from the PC to the device through a
straight cable, and you can talk from the Stamp to the PC with a
straight cable, then you need a cross cable to talk between the Stamp
and the device (how's that for a syllogism?).
What is it that makes you certain it is a voltage-related issue?
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: tony.wells@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=3Ywr6LucOc0_PHX4m4Zly-yb5Quij5jyv6K1gduFK9rSa_MhOtNNoimy1U63Xx7ohq-8DrN26BatJZlDLw]tony.wells@a...[/url
> Sent: Monday, January 21, 2002 4:13 PM
> Subject: [noparse][[/noparse]basicstamps] 5V TTL to true rs232
> Hi Folks,
> RX which is
> interface, but the device remains silent. This seems to be
> +just
> I know it is not my code because I've done lots of
> subsitution testing to prove the assertion on the 8v issue.
> 12v or higher? I'm so desperate I'm willing to work with a
> Thanks
> Tony Wells
> from the same email address that you subscribed. Text in the
using a max232 chip they invert the data stream
Sent: January 21, 2002 2:35 PM
Subject: RE: [noparse][[/noparse]basicstamps] 5V TTL to true rs232
Hi Tony,
the
trick.
driver
are in
vendors
carries
these.
hook your
else to
through a
Stamp
Al Williams
AWC
> From: tony.wells@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=eCGPf2C95O3sf6eS3g0zPRZblgEUIPnGIQgB_b76PdS2RzK_Ztje7H6BS8rQdZ-9JgiwY1Pv_wW6pC3c65mJ2vc]tony.wells@a...[/url
> Hi Folks,
> RX which is
which
> +just
> Thanks
> Tony Wells
I'm aware of the 1488 thanks, but was hoping there was a 5v powered chip
which outputs +/- 12v.
I'm absolutely sure it is voltage related because::
a. The external device (a Rugby MSF receiver) is normally powered from the
rs232 line and when I connected the device to the PC I identified the pin
supplying -12v from the PC which causes the device to wake up. When I simply
move the same wire from the PC end and move it across to the Stamp Max232
equivalent which supples -8v the device goes back to sleep and remains as
sleepy as Mr Sleepy in Sleepyville. When I move the wire back to the PC the
device wakes up and is as alert as Mr Rabbit in a field of angry farmers!
> trick.
*Your* max232 is working fine - its was for another project which is done
and dusted....
Sent: Monday, January 21, 2002 10:35 PM
> Hi Tony,
> trick.
> these.
> Al Williams
> AWC
> > From: tony.wells@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=Nu6GQ1dDKlVq5PdOqrKwpal-WIcmENA3XbLgDq3iNTN2srgoRaFJytebDmWbJ2FnP9Pq6MkC1tke48B7dg]tony.wells@a...[/url
> > Hi Folks,
> > RX which is
> > +just
> > Thanks
> > Tony Wells
The max232 generates normally +/- 10V from a single 5V and requires four
0.1uF caps to do so.
It may be your device draws a little bit more current than usual hence
the -8V.
I regarly use 10uF caps without problems and these keep the voltages to +/-
10V.
With the increased caps you can draw more current without decreasing the
voltages too much.
Regards peter
Oorspronkelijk bericht
Van: tony.wells@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UxKDjy5XEYxAUrhSzDpjRNi4-ZFWysOe-J17QQaEySSCzBwrKuSQ8OlUzF6VB7wgo_4CKF91R6aXdClhkXB2ZQ]tony.wells@a...[/url
Verzonden: maandag 21 januari 2002 20:25
Aan: basicstamps@yahoogroups.com
Onderwerp: Re: [noparse][[/noparse]basicstamps] 5V TTL to true rs232
> trick.
and dusted....
> Hi Tony,
> trick.
> these.
> Al Williams
> AWC
> > From: tony.wells@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=UxKDjy5XEYxAUrhSzDpjRNi4-ZFWysOe-J17QQaEySSCzBwrKuSQ8OlUzF6VB7wgo_4CKF91R6aXdClhkXB2ZQ]tony.wells@a...[/url
> > Hi Folks,
> > RX which is
> > +just
> > Thanks
> > Tony Wells
The MAX232A uses .1uF caps. The MAX232 uses 1uF caps.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
> From: peter verkaik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=AnLOdpzBFgqrJc-QiImOmyygKojPPnq6gq3Z0pXgD-ifeTUGp4VTSsmjnAWMota_w2dXhDLHvtPjdGjAdxKgsQ]peterverkaik@b...[/url
> Sent: Monday, January 21, 2002 11:48 PM
> Hi,
> requires four 0.1uF caps to do so. It may be your device
> draws a little bit more current than usual hence the -8V. I
> voltages to +/- 10V. With the increased caps you can draw
> more current without decreasing the voltages too much.
> Regards peter
> Van: tony.wells@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=drJGvids_7xRfqk4RwVrW1_BB_JSSCoZ_sfKYtO0mjNeLoee7RRFuZ6W4GRzzgFMohfjfJzqEZKDVKG9d0mP]tony.wells@a...[/url
> > your Stamp to the PC does it seem to do what you expect? Something
> > else to think about: if you are able to talk from the PC to
> the device
> > through a straight cable, and you can talk from the Stamp to the PC
> > with a straight cable, then you need a cross cable to talk
> between the
> > Stamp and the device (how's that for a syllogism?).
> powered chip which outputs +/- 12v.
> powered from the rs232 line and when I connected the device
> to the PC I identified the pin supplying -12v from the PC
> which causes the device to wake up. When I simply move the
> Max232 equivalent which supples -8v the device goes back to
> sleep and remains as sleepy as Mr Sleepy in Sleepyville. When
> I move the wire back to the PC the device wakes up and is as
> to do the
> > trick.
> which is done and dusted....
> From: "Al Williams" <alw@a...>
> > Hi Tony,
> to do the
> > trick.
> line driver
> you are in
> some vendors
> > these.
> the device
> between the
> > Al Williams
> > AWC
> > * Floating point A/D http://www.al-williams.com/awce/pak9.htm
> > > From: tony.wells@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=drJGvids_7xRfqk4RwVrW1_BB_JSSCoZ_sfKYtO0mjNeLoee7RRFuZ6W4GRzzgFMohfjfJzqEZKDVKG9d0mP]tony.wells@a...[/url
> > > Hi Folks,
> > > which is
> +/-8v which
> > > +just
> 12v. I know
> > > it is not my code because I've done lots of subsitution
> testing to
> true 12v or
> > > Thanks
> > > Tony Wells
> the Subject
> > and
I use 10uF caps on the max232N. No sweat.
Regards peter
Van: Al Williams [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=b31psb3ci4a5aQGNhTn87JHgGKYHxULwo5GaouaOLfR7Csym3MVAONYPok1AaZTAJBsTS4aGeCm7tHzJ]alw@a...[/url
Verzonden: dinsdag 22 januari 2002 05:29
Onderwerp: RE: [noparse][[/noparse]basicstamps] 5V TTL to true rs232
Hi Peter,
Al Williams
AWC
> From: peter verkaik [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YReSCJpGeyo_FUKjMqVlD3vcsO_huCd892-7SQ2l3EvzeWxTiaTJEoEfsd4s75A_dZzQ3ZHHVxu1QRfDh8A8rAqzsMs]peterverkaik@b...[/url
> Hi,
> Regards peter
> Van: tony.wells@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tcyo_lMF7MtaVCytHV0Ihx5-ss4sUGis0NX84_gulL9MZY8eHSsBTVeftoxHDeYwP7mFBu7pRocdIyC_kl5onw]tony.wells@a...[/url
> the device
> between the
> to do the
> > trick.
> > Hi Tony,
> to do the
> > trick.
> line driver
> you are in
> some vendors
> > these.
> the device
> between the
> > Al Williams
> > AWC
> > > From: tony.wells@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=tcyo_lMF7MtaVCytHV0Ihx5-ss4sUGis0NX84_gulL9MZY8eHSsBTVeftoxHDeYwP7mFBu7pRocdIyC_kl5onw]tony.wells@a...[/url
> > > Hi Folks,
> > > which is
> +/-8v which
> > > +just
> 12v. I know
> testing to
> true 12v or
> > > Thanks
> > > Tony Wells
> the Subject
> > and
