ground plane question
Hello,
I have a board with ground plane and before holding the BS2 and other IC's
in sockets I tested the board power.
I have connected the o/p of the transformer to the board terminal and the dc
voltage was OK but there is something I have found , when I touch the ground
area I feel a little vibration in my finger,it seems like a kind of ac
source.This disappear when I reverse the main terminal.Any explanation would
be appreciated.
Thank You
Mohamed Refky
_________________________________________________________________
MSN Photos is the easiest way to share and print your photos:
http://photos.msn.com/support/worldwide.aspx
be appreciated.
Thank You
Mohamed Refky
transformer to your ground plane. The AC primary side of the transformer
should be completely isolated from the secondary side winding and your
ground plane.
Steve
Sent: Monday, January 21, 2002 1:17 PM
Subject: [noparse][[/noparse]basicstamps] ground plane question
> Hello,
dc
ground
would
> be appreciated.
> Thank You
> Mohamed Refky
