sensor — Parallax Forums
sensor
edited 2003-06-06 00:06 in General Discussion
i am looking for something to trigger a basic stamp when a rc car
drives close to or over the sensor any idea's
thanks
Travis
    edited 2002-01-22 01:21
    Hi Travis,
    Is it a closed track that you can put a IR sensor across so when a
    car passes it breaks the signal ?
    or maybe a single car lane wide so you can put a light sensor in the
    bottom looking up and again a passing car will change the value.
    This is what they do for paint balls (and rifle bullets) to test
    speed.
    There was a thread here some 6 months ago on such a device.
    Dave
    > thanks
    > Travis
    edited 2003-04-17 19:17
    hi,
    i am working on a gasoline sensor project. i have used a gas sensor
    and callibrated the values in ppm i.e for eg. 1v give 100ppm, 1.6v
    give 500ppm ,3v give 1000ppm and so on. i plotted these point in a
    excel sheet and got a graph that passes through all the points. now i
    have to display the ppm values on an LCD . i want to use a
    microcontroller to fit the graph in it. i do not have an idea how to
    do it.. can anyone help me..
    thank you
    venkata
    Ok the file is called sensor if someone has a few minutes. The sensor only has
    three wires. Power, ground and communication. It is not the one wire protocal.
    Any help with this thing would be appreciated.
