Quick RS232 question
I am looking for a microcontroller that can send information to 2
separate RS232 ports. My application is to make a simple controller
to sequence two video projectors.
Is it possible to configure the BS2-IC to do this? I probably don't
need to rx RS232 data.
Sorry if this is a very obvious question but I am trying to find a
quick solution.
TIA
Paul Wilton
email Paul.Wilton@R...
quick solution.
TIA
Paul Wilton
Paul.Wilton@R... writes:
Yes, this is possible with the BASIC Stamp. You can send serial data from
any of its I/O pins. Technically you can only use one pin at a time, but I
suspect you're not transmitting a lot of data and this one be a problem.
-- Jon Williams
-- Parallax
to send data. The only catch is that all ports (except port "16" the
programming port) are TTL/CMOS levels (0 and 5V) which is not really to
the RS232 spec. That being said, most devices will read 0 and 5V levels
fine. However, if you really want to connect to a "true" RS232 port and
want all the right voltage levels, short protection, etc. you need a
driver like a MAX232. Check out http://www.al-williams.com/awce/rs1.htm.
Al Williams
AWC
* Floating point math for the Stamp, PIC, SX, or any microcontroller
http://www.al-williams.com/awce/pak1.htm
> From: wilts123 [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=jrSe7Ynef5iGkP2dUbdnM4S4R-cqVKlTcCWi_XZJzOWKuMdp-VAUmeiwyXQEsdU2cqmp4rvpkFcqWNoqHVGIDw]Paul.Wilton@R...[/url
> Sent: Monday, January 21, 2002 3:24 AM
> Subject: [noparse][[/noparse]basicstamps] Quick RS232 question
> quick solution.
> TIA
> Paul Wilton
> from the same email address that you subscribed. Text in the
