help....
Hi there!
Long time no post.
Anyways, I was wondering if anyone can help me out.
I have a BS2SX micro controller, and it is connected to a
transceiver. At a computer, I have another transceiver. The
computer is using C code to display the characters that is
transmitted from the BS2SX. The computer can also send out data to
the BS2SX, and it will receive and print the data to screen.
My problem is, the further I separate the two transceivers, the more
bit error I get, and the more funny characters I receive. What would
you suggest to do error checking? I'm assuming I'd have to code the
error checking, but, programming is one of my weaknesses.
Is there a way to do parity checking? One thing I don't understand
is that if there is an error, how do i request for it to be resent?
or does it do it automatically?
Please also note that at the computer side, the transceiver is
connected to the serial port of the computer (ie, there is no BS2SX
at the computer terminal).
Thanks!
Debu
ps- here is the C code i'm using at the computer side
#include <dos.h>
#include <stdio.h>
#include <conio.h>
#define PORT1 0x3F8
#define PORT2 0x2F8
/* Defines Serial Ports Base Address */
/* COM1 0x3F8 */
/* COM2 0x2F8 */
/* COM3 0x3E8 */
/* COM4 0x2E8 */
void main(void)
int c;
int ch_in = 0;
int ch_out = 0;
outportb(PORT1 + 1 , 0); /* Turn off interrupts - Port1 */
/* PORT 1 - Communication Settings */
outportb(PORT1 + 3 , 0x80); /* SET DLAB ON */
outportb(PORT1 + 0 , 0x30); /* Set Baud rate - Divisor Latch Low
Byte */
/* Default 0x03 = 38,400 BPS */
/* 0x01 = 115,200 BPS */
/* 0x02 = 57,600 BPS */
/* 0x06 = 19,200 BPS */
/* 0x0C = 9,600 BPS */
/* 0x18 = 4,800 BPS */
/* 0x30 = 2,400 BPS */
outportb(PORT1 + 1 , 0x00); /* Set Baud rate - Divisor Latch High
Byte */
outportb(PORT1 + 3 , 0x03); /* 8 Bits, No Parity, 1 Stop Bit */
outportb(PORT1 + 2 , 0xC7); /* FIFO Control Register */
outportb(PORT1 + 4 , 0x0B); /* Turn on DTR, RTS, and OUT2 */
printf("\nPress ESC to quit \n");
do { c = inportb(PORT1 + 5); /* Check to see if char has
been */
received. */
if (c & 1) {
ch_in = inportb(PORT1); /* If so, then get Char*/
if (ch_in != ch_out) {
printf("PORT1-R = %c \n",ch_in); /* Print Char to
Screen*/
if (kbhit()) {
ch_out = getch(); /* If key pressed, get Char */
printf("PORT1-S = %c\n",0x55);
outportb(PORT1, ch_out); /* Send Char to Serial Port */
} while (ch_out !=27); /* Quit when ESC (ASC 27) is pressed */
Long time no post.
Thanks!
Debu
#include <dos.h>
#include <stdio.h>
#include <conio.h>
#define PORT1 0x3F8
#define PORT2 0x2F8
/* COM1 0x3F8 */
/* COM2 0x2F8 */
/* COM3 0x3E8 */
/* COM4 0x2E8 */
void main(void)
int c;
int ch_in = 0;
int ch_out = 0;
Byte */
Byte */
been */
received. */
if (c & 1) {
Screen*/
if (kbhit()) {
distance. Review the application notes that talk about max distance allowed
between the Transceiver units.
Steve
Sent: Thursday, January 17, 2002 7:39 PM
Subject: [noparse][[/noparse]basicstamps] help....
> Hi there!
> Long time no post.
> Thanks!
> Debu
> #include <dos.h>
> #include <stdio.h>
> #include <conio.h>
> #define PORT1 0x3F8
> #define PORT2 0x2F8
> /* COM1 0x3F8 */
> /* COM2 0x2F8 */
> /* COM3 0x3E8 */
> /* COM4 0x2E8 */
> void main(void)
> int c;
> int ch_in = 0;
> int ch_out = 0;
> Byte */
> Byte */
> been */
> received. */
> if (c & 1) {
> Screen*/
> if (kbhit()) {
The stamp produces a ton of energy in the RF spectrum, some of which is in
the wireless frequency bands. Some of this might be overloading the receiver
side, truncating the sometimes optimistic distance specification of the
units.
It will take too long to explain all the methods used to shield your RX and
antenna, but the simplest was is to shield the stamp with a tin box
connecting the box to ground. For further improvement connect a 10 pico
farad ceramic capcitor to ground fom each wire that comes out of the tin
box.
Tony Wells
The Inventor of Luminous Custard
Sent: Friday, January 18, 2002 6:01 AM
Subject: Re: [noparse][[/noparse]basicstamps] help....
> You have a RF path loss between the transceivers which is a function of
allowed
> Steve
> From: "debu_sen_22" <debu_sen_22@y...>
> > Hi there!
> > Long time no post.
> > Thanks!
> > Debu
> > #include <dos.h>
> > #include <stdio.h>
> > #include <conio.h>
> > #define PORT1 0x3F8
> > #define PORT2 0x2F8
> > /* COM1 0x3F8 */
> > /* COM2 0x2F8 */
> > /* COM3 0x3E8 */
> > /* COM4 0x2E8 */
> > void main(void)
> > int c;
> > int ch_in = 0;
> > int ch_out = 0;
> > Byte */
> > Byte */
> > been */
> > received. */
> > if (c & 1) {
> > Screen*/
> > if (kbhit()) {
and
