Can anyone explain to me how the 555 IC works in the Earth Measurements Project?
Quite Confuses me, the capacitor is connected to 1(GROUND) and 2
(TRIGGER) the resistor is in 2(TRIGGER) and 3(OUTPUT), how do this do
the dsicharging and charging, and how this works?
The output is inverted from the input: when the voltage on the cap is LO,
the output is HI and the cap charges thru the resistor. When the threshold
voltage is reached (2/3 Vcc), the output goes LO and discharges the cap via
the resistor.
Its similar to the standard circuit but requires 1 less resistor and can
provide a more accurate 50 duty cycle *IF* the '555 is one of the CMOS
variants.
dwayne
Dwayne Reid <dwayner@p...>
Trinity Electronics Systems Ltd Edmonton, AB, CANADA
(780) 489-3199 voice (780) 487-6397 fax
Celebrating 18 years of Engineering Innovation (1984 - 2002)
Do NOT send unsolicited commercial email to this email address.
This message neither grants consent to receive unsolicited
commercial email nor is intended to solicit commercial email.
