alias into an array
Group:
Is it possible to establish an alias into a byte array using the bs2? I
have read the
"Alias and Modifiers" section of the Basic Stamp manual, but it only
addresses
aliases into words, bytes, and nibs.
Basically, I want the following lines of code to work:
my_byte_array var byte(10) ' a 10 byte array
alias_byte var my_byte_array(3) ' establish an alias for the 4th
byte
This code results in error messages. Does anyone know if what I'm
trying to do
is possible, and how? Thanks.
Clark Hughes
have read the
addresses
byte
trying to do
Clark Hughes
not explicitly declared. Since variables of the same type are allocated in
the order of their declaration, you can use the technique below to get around
your situation. It takes a bit more typing, but works as you want it to.
-- Jon Williams
-- Parallax
' {$STAMP BS2}
myArray VAR Byte ' declare array name
array0 VAR myArray ' align (alias) first byte to array name
array1 VAR Byte
array2 VAR Byte
array3 VAR Byte
idx VAR Nib
Test:
FOR idx = 0 TO 3
myArray(idx) = idx
NEXT
DEBUG DEC ?array2
END
In a message dated 1/16/02 1:15:18 PM Central Standard Time,
jchughes@a... writes:
> Group:
> have read the
> addresses
> byte
> trying to do
Question from a stamp newbie:
I read in the memory section that the BS2 allocated (I think) 26 bytes for
variables. Does allocating an alias use memory allocated for variable
storage. I understand that it's referencing the variable pointed to, but you
still have to store the alias name and the address of the variable
referenced.
Cheers
Peter Kerr
From: jonwms@a... [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=H9WUc3TZ2Q9FFD7TSgiP7l3UdkRFnnGV2q1-iHcVkKPumnrcRa2oBFSmatH2prF5hqLHmuC2WbSu]jonwms@a...[/url
Sent: Wednesday, January 16, 2002 11:25 AM
Subject: Re: [noparse][[/noparse]basicstamps] alias into an array
The Stamp variable memory can be treated like an array of any type -- even
if
around
-- Jon Williams
-- Parallax
' {$STAMP BS2}
name
array1 VAR Byte
array2 VAR Byte
array3 VAR Byte
idx VAR Nib
Test:
FOR idx = 0 TO 3
myArray(idx) = idx
NEXT
DEBUG DEC ?array2
END
> Group:
> have read the
> addresses
> byte
> trying to do
Thanks for the reply. I see what you're doing - reading "past" the declared
variable. That will work fine for my application. It appears that multiple
declarations require no more program space than the single declaration of
the array, so that is good news as well. Thanks for your assistance.
Clark
jonwms@a... wrote:
> The Stamp variable memory can be treated like an array of any type -- even if
> -- Jon Williams
> -- Parallax
> ' {$STAMP BS2}
> array1 VAR Byte
> array2 VAR Byte
> array3 VAR Byte
> idx VAR Nib
> Test:
> FOR idx = 0 TO 3
> myArray(idx) = idx
> NEXT
> DEBUG DEC ?array2
> END
> > Group:
> > have read the
> > addresses
> > byte
> > trying to do
J. Clark Hughes
Applied Research Laboratories
The University of Texas
Austin, Texas
Experiment a little with the editor and you will see
that the alias does not take up any more variable
space. This makes sense, since it could just be stored
in the program memory. But, lo and behold, it doesn't
take up any more program/EEPROM space either. Why? The
alias are present in the editor for the convenience of
the programmer, but once tokenized, every occurence of
a variable - whether as its original name or as an
alias - need only be stored in a way that the BASIC
interpreter can read it. The interpreter has no need
to distiguish, it only needs to know the variable
location to examine.
Bob Pence
--- Peter Kerr <peter.kerr@z...> wrote:
> Nice solution Jon
> of the variable
> referenced.
> Cheers
> Peter Kerr
[noparse][[/noparse]snip]
__________________________________________________
Do You Yahoo!?
Send your FREE holiday greetings online!
http://greetings.yahoo.com
So an alias is handled the same as a CON. Both are handled/substituted at
the pre-processor stage?
Peter
From: Pence Bob [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=G8m22EIW2rGVuwtqse3nYCmuAaaNEm2WqJAhTOv5SSQUZmnuHg0IjUdH3wCT9NRCvzjaH-El_hb7w60LL5k]bobpence_2000@y...[/url
Sent: Wednesday, January 16, 2002 12:00 PM
Subject: RE: [noparse][[/noparse]basicstamps] alias into an array
Peter -
Bob Pence
> Nice solution Jon
> of the variable
> referenced.
> Cheers
> Peter Kerr
Do You Yahoo!?
C/C++ coders are familiar with. There is a difference
in that the variable value is stored in the variable
space, with a handle for it in the program area, while
the constant would presumably become a literal in the
program area.
The length of a variable's handle (a term here used
loosely) in the program area is essentially fixed,
while the length of a literal (and therefore a
constant) depends on the size of the value. So the
question arises, could a program with a nearly-full
EEPROM program area and spare variable space have some
of its program area freed up by replacing constants or
repeated literals with variables? A little
experimentation seems to indicate that the space
consumed by each variable handle (whether the variable
is a bit, nibble, byte, or word) is no less than the
space used by a word-sized literal or constant, so the
answer would be, no. However a similar setup might
make sense for other processors that split variable
and program space in a similar way.
Bob
> Thanks Bob
> Peter
> From: Pence Bob [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=s05kg7hvfRbdoha82QmZJgKxEWS8JicYXs3zz5mt1A9A9AejzYv7RCu_2sqZn4GiH790V4d9V4GiInjfy8ldgg]bobpence_2000@y...[/url
> Peter -
> stored
> doesn't
> The
> of
> of
> Bob Pence
Do You Yahoo!?
Send FREE video emails in Yahoo! Mail!
http://promo.yahoo.com/videomail/
peter.kerr@z... writes:
Aliasing does not use any more memory -- it simply gives the same storage
location another name. This can be useful (reuse of space with logical
names), but it can lead to problems too.
When using aliases, you must be careful that one part of the program doesn't
stomp on a piece of data in use or expected somewhere else.
-- Jon Williams
-- Parallax
