OBD2 project
Peter-
Async serial is always LSB first. Not sure if that's what you mean
to be doing (i.e., sending inverted). I think I'd also use PAUSE
vice NAP for greater precision. If you're using a line driver, try:
ser_pin CON 1 ' or whatever
LOW ser_pin: GOSUB delay ' start bit (RS232 high)
HIGH ser_pin: GOSUB delay ' low order bit 0
GOSUB delay ' repeat for bit 1
LOW ser_pin: GOSUB delay ' bit 2
GOSUB delay ' bit 3
HIGH ser_pin: GOSUB delay ' bit 4
GOSUB delay ' repeat for bit 5
LOW ser_pin: GOSUB delay ' bit 6
GOSUB delay ' high order bit 7
HIGH ser_pin: GOSUB delay ' stop bit
(initial transmission complete at this point)
delay:
PAUSE 200: RETURN
Is this OBD-II transmission protocol described on a web site
somewhere?
Steve
GOSUB delay ' bit 3
delay:
PAUSE 200: RETURN
somewhere?
Steve
I'm building an OBD-II interface board so I can talk to my in car ECU from a
handheld. The interface card was originally just to shift the line levels
from TTL to RS232 and add opto-isolation, however I thought I would add a
stamp to handle the message formatting, heartbeat, changes in baud rate etc.
Communication is initiated by sending 0x33 at 5 baud and then switching to
10400 baud. The 10400 shouldn't be an issue, however I can use SEROUT for 5
baud. I'm using a BS2 and the formula INT(1,000,000,baudrate)-20 overflows
the 12(?) bit wide setting.
Seeing as I only have to send the 0x33 once, (all further communication is
done at 10,400) I figured that I could just manually strobe it out the I/O
line.
I'm sending a start bit, low ,low, high, high, low, low, high, high, and
stop bit, using NAP to pause between switching the bits. I know NAP isn't
guaranteed to be all that accurate or consistant, but I'm not getting any
joy at all. Has anyone done anything similar?
I'm pretty new to stamp/microcontroller applications and would appreciate
any suggestions.
Cheers
Peter Kerr
> Hi
a
etc.
5
> line.
> any suggestions.
> Cheers
> Peter Kerr
The output pin drives a npn transistor which inverts the signal, I'm not
sure if thats what you mean by a line driver.
I've just done some more reading and found that RS232 data lines are
inverted. I'm not sure if the ECU conforms to this so I'll do some testing.
Re ODB-II transmission protocol:
Details of this are incredibly hard to get. The seems to be three seperate
parts:
Hardware spec - ie what protocol is used. This is manufacturer based. more
details at www.obdii.com
OBD-II generic spec SAE J1979 www.sae.org do a search for J1979. I have
yet to purchase this.
Manufacturer specific Device Trouble Codes (DTC)
Some more details are at http://www.andywhittaker.com/ecu/obdii_software.htm
Hope this helps
Peter kerr
From: S Parkis [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=YRt1-PY2FAMLwG4gVhopEUDddKPMnKNQvWtvLcE29wcnzBVce7xOPhypcYRSwe3EEsCOzcTufNpKGhbM6h4GJw]parkiss@e...[/url
Sent: Tuesday, January 15, 2002 7:32 PM
Subject: Re: [noparse][[/noparse]basicstamps] OBD2 project
Peter-
GOSUB delay ' bit 3
delay:
PAUSE 200: RETURN
somewhere?
Steve
[noparse][[/noparse]snip]
> somewhere?
B&B Electronics <http://www.bb-elec.com/> at one time had an
application note available describing OBDII. I see they have now
created a separate company <http://www.autotap.com/> and I can't seem
to find that app note now.
Greg
--- In basicstamps@y..., Peter Kerr <peter.kerr@z...> wrote:
> Hi
ECU from a
levels
would add a
rate etc.
switching to
SEROUT for 5
overflows
communication is
the I/O
> line.
high, and
NAP isn't
getting any
appreciate
> any suggestions.
> Cheers
> Peter Kerr
