sensor chatter
Hello,
I'm using radio shack digital ir detectors to control a small robot.
I need to have it maneuver fairly tight clearances, and therefore
sense tight clearances.
Here is my problem:
I'm creating my IR pulses with a PAK8 co processor, it makes much
more precise pulses than the stamp can. When using a stamp to create
the transmitter frequency, the variating high's and low's of each
pulse apperently "confuse the detector", and therefore it decides to
hold it's output state longer, making for a more stable reading.
With the pack8's precision, I have chatter like crazy, this could
sende my robot into a dance. Since i only have an inch or two
clearance on either side of it, i'm asking for sugestions on how I
can eliminate chatter as simply and cheaply as possible.
thanks in advance
Chris
Here is my problem:
thanks in advance
Chris
I'm not sure this is correct. The Stamp and the PAK both use ceramic
resonators, so they should be about the same precision-wise. I would
more suspect that the 50MHz clock on the PAK is interfering with the
detector and making it chatter. Do you have a .1uF capacitor across the
detector's power right at the detector? You might also try putting a cap
on the detector's output to stop "fast" pulses that are common with
these detectors.
Are you on a solderless breadboard? Remember, these are big capacitors,
so the noise from the 50MHz oscillator will spread easily and you have
to have especially careful bypassing.
Al Williams
AWC
* Easy RS-232 Prototyping
http://www.al-williams.com/awce/rs1.htm
little, unevenly spaced pulses as I understand,
whereas the pak doesn't?
If I pulse my servos via pulseout i'd have to
recalibrate all my servos as their center would be
really far off, it really seems like the pak is more
precise in that respect, resonator aside.
I am still currently on a solderless breadboard at
this stage, i'll be transferring to pcb very soon. I
have a .1uf cap across power for the detector and
tried switching it to go across output/ground yet that
seemed to make little difference. The resonator is
wired to it's own bus which the pak and stamp both
share and that's filtered using a few caps, (what size
caps are commonly used for filtering a five volt
supply in this manner, i just stuck in what i could
find....47uf i think).
By playing with resistor values inline with both the
transmitters and the output of the detector i was able
to adjust ....somewhat close enough for the range i
need, and chatter is no longer a problem if they are
both pointing straight out to space. It will still
begin to chatter from say six inches away, and i'll
get a solide reading at about one inch from it. I'm
thinking of implementing comparators, and if i do that
i may as well modify my detectors to read analog wich
also brings their range down to something i can really
use. Any sugestions are most welcome.
I'd like to thank you for all your help Al, pak8 is
controlling all my IR and four servo's on a 5us
prescale, works excellent.
> a stamp to create
> and low's of each
> stable reading.
> crazy, this could
> inch or two
> sugestions on how I
> possible.
> both use ceramic
> are common with
> these detectors.
> are big capacitors,
> easily and you have
> Al Williams
> AWC
> from the same email address that you subscribed.
> Text in the Subject and Body of the message will be
> ignored.
______________________________________________________________________
Web-hosting solutions for home and business! http://website.yahoo.ca
> The stamp creates a high pulse by sending alot of
The PWM and FREQOUT commands works like this. But PULSOUT should just
make a solid pulse (just one pulse though). What are you using on the
Stamp?
> transmitters and the output of the detector i was able to
> adjust ....somewhat close enough for the range i need, and
> chatter is no longer a problem if they are both pointing
> straight out to space. It will still begin to chatter from
> say six inches away, and i'll get a solide reading at about
> one inch from it. I'm thinking of implementing comparators,
> and if i do that i may as well modify my detectors to read
> analog wich also brings their range down to something i can
> really use. Any sugestions are most welcome.
> I'd like to thank you for all your help Al, pak8 is controlling all my
> IR and four servo's on a 5us prescale, works excellent.
How many outputs are you using on the PAK? Using more than 4 @ 5uS will
cause problems because there isn't enough time to always service 5 or
more outputs that fast (10uS works fine). I'm assuming you are driving
all your servos from one output?
Al Williams
AWC
pulsout in a loop, the servos should have come
pre-calibrated, however using pulsout, they were
uncontrolable, therefore I recalibrated one of them.
After which i recieved my pak8, found the three servos
which still couldn't be centered with the stamp (and
still at their pre-calibration settings) were
perfectly centered using the pak, and the one that was
now centered on the stamp needed to be calibrated yet
again for use on the pak. freqout had the same
results. That's why i came to the conclusion the pak
is far more accurate. I haven't tested it on a scope
but if i did i'm certain there would be some
difference, at least enough of one to throw off
servos.
It would be interesting to compare them anyway.
Maybe you could give me some pointers. I have a hard
time calculating math for certain things. EX: I want
to design a schmitt trigger using a 311 comparitor,
power supply is 5, detectors go from say 2 something
to 3 something, I need a voltage divider for the
positive feedback, and I "think" another to set the
voltage i want it to switch at. So i'll have one
divider going into another. So after a bit more
research i'll know all the values I'll need in the end
but is there a simple way to figure out the resistor
values for the dividers that will give me the ratios
i'm after? or must it be a trial and error, plug a
value in and crunch the numbers type of deal. yes i'm
serious.
> PULSOUT should just
> you using on the
> Stamp?
> more
> I
> that
> size
> could
> the
> able to
> need, and
> pointing
> chatter from
> at about
> comparators,
> to read
> something i can
> excellent.
> always service 5 or
> Al Williams
> AWC
> ignored.
at a certain voltage. This usually requires a voltage divider to set a
trip point and then you feed the other voltage into the other comparator
input. I'm not sure what you mean about two dividers. One thing to
remember is that the divider only works when you have a very high input
impedance. I'll show you why in a minute. However, you might also enjoy
reading http://www.al-williams.com/wd5gnr/basiccir.htm.
If you want to design instead of guessing at a voltage divider, you
decide how much current you want the divider to draw. Say you have a 12V
supply and you want a 1/3 divider. You'd like to draw, say 1mA through
the divider. So the total resistance must be:
.001 = 12/R or R=12K
Now you want 4V out so the ratio is 1/3. So if the "bottom" resistor is
R2 and the "top" resistor is R1 you want R2/(R1+R2)=1/3 or 3=(R1+R2)/R2
or 3R2-R2 = R1 which of course is 2R2=R1. Right?
So now you have two equations: 2R2=R1 and R1+R2=12K. You can probably
make a good guess now, but if you like you can solve this
mathematically. Subtracting R1=2R2 from the other equation gives you:
R2=12K-2R2 or 3R2=12K or R2=12K/3 so R2=4K. Going back to R1+R2=12K and
substituting 4K you can find out that R1 then is 8K.
So 8K and 4K are the magic numbers. Just to be sure: 12 * 4K/(8K+4K) =
4V. So that works.
If you build this and look at it with a modern VOM (probably 10Mohm
input) everything is fine. A comparator would be pretty good too since
they have high input impedence. But humor me and pretend we are hooking
up an A/D converter with a 10K input impedance. Oh oh. Now R2 is not 4K.
It is 4K in parallel with 10K (about 2.9K). That throws the divider off
by a massive amount (2.9K/(8K+2.9K)=.27 not .33). When your 4K is in
parallel with 1 or 10M the error is small (4K in parallel with 1M is
3.984K -- about .4% off.
That's the problem with "ganging" dividers as you proposed. Picture a
divider with resistors R1A and R2A that divides 1:3 (so we can keep our
4K and 8K). Now, we want to split that voltage in half for some reason.
Say we pick two 10K resistors to do that (R1B and R2B). This throws our
first divider "off" because now instead of 4K, we have 4K in parallel
with 20K (3.33K). So the first divider really "computes" 3.33/(8+3.33) =
which is about .3, not .33. Then the 50/50 divider will cut that in
half.
So often, instead of designing a divider for current, the real question
will be: what total resistance do I want. For example, if the second
divider was very large in total resistance, this problem would be
minimal (and, in fact, since 20K>>4K it isn't that bad).
By the way, this gives you a intuitive feeling for why the maximum power
transfer theorem works (read the Web page on Thevenin equivalents). But
I've gone on too long as it is, so I'll leave that as an exercise to the
reader.
Al Williams
AWC
* Floating point A/D
http://www.al-williams.com/awce/pak9.htm
> From: c bielek [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=iYeC0GbSCqJ8lHLrItzwoSvXn7gBJWiNEP_vnNwMWjOGZptWDxQWYuwzBHM3Q7pVM6hDf137]cbielek@y...[/url
> Sent: Wednesday, January 16, 2002 4:29 PM
> Subject: RE: [noparse][[/noparse]basicstamps] sensor chatter
> I just initially tested the servo calibration using
> pulsout in a loop, the servos should have come pre-calibrated, however
> using pulsout, they were uncontrolable, therefore I recalibrated one
> of them. After which i recieved my pak8, found the three servos
> servos.
> value in and crunch the numbers type of deal. yes i'm serious.
> > PULSOUT should just
> > you using on the
> > Stamp?
> > more
> > I
> > that
> > size
> > could
> > the
> > able to
> > need, and
> > pointing
> > chatter from
> > at about
> > comparators,
> > to read
> > something i can
> > excellent.
> > always service 5 or
> > Al Williams
> > AWC
> > * Easy RS-232 Prototyping http://www.al-williams.com/awce/rs1.htm
> > ignored.
> ________
> from the same email address that you subscribed. Text in the
results when controlling a servo. Thanks for your results.
Steve
Sent: Wednesday, January 16, 2002 2:28 PM
> servos.
> serious.
> > PULSOUT should just
> > you using on the
> > Stamp?
> > more
> > I
> > that
> > size
> > could
> > the
> > able to
> > need, and
> > pointing
> > chatter from
> > at about
> > comparators,
> > to read
> > something i can
> > excellent.
> > always service 5 or
> > Al Williams
> > AWC
> > ignored.
