Those switches work for the Stamp 2 on a serial port, but it doesn't
seem to work (i.e., hardware not found) for a Stamp 1 on a parallel
port.
What type of parallel port do I need (e.g., bidirectional, EPP,
ECP, ...)
Greg
--- In basicstamps@y..., "Al Williams" <alw@a...> wrote:
> If I remember correctly, put /1 /2 or /3 after the command line.
> Al Williams
> AWC
> * Floating point A/D
> http://www.al-williams.com/awce/pak9.htm
> > From: shueyville_greg [noparse][[/noparse]mailto:gregory-wagner@u...]
> > Sent: Monday, January 14, 2002 10:31 AM
> > To: basicstamps@y...
> > Subject: [noparse][[/noparse]basicstamps] Stamp 1 Editor
> > Is there a way to tell the Stamp 1 Editor which parallel port to
use
> > on a PC with more than one?
> > Greg
> > To UNSUBSCRIBE, just send mail to:
> > basicstamps-unsubscribe@y...
> > from the same email address that you subscribed. Text in the
> > Subject and Body of the message will be ignored.
> > Your use of Yahoo! Groups is subject to
> > http://docs.yahoo.com/info/terms/
Oops, make that "the editor doesn't even load" instead of "hardware
not found." The only command line switches seem to be /h for help
and /m for monochrome mode.
Greg
--- In basicstamps@y..., "shueyville_greg" <gregory-wagner@u...>
doesn't
> port.
> ECP, ...)
> Greg
> > Al Williams
> > AWC
to
> use
> > > Greg
Sorry! That was from memory and apparently faulty memory. Looks like it
must detect the Stamp, which means you probably have some other problem.
Could it be power or a faulty cable?
> From: shueyville_greg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=1F_xxyABkmU1lqX1hRh1P4TBeN-fePt8rsx3idZLFsThf-OUFLdyf-BAab_1_8-6pB9soIGqyL8wFsLZ64JP]gregory-wagner@u...[/url
> Sent: Monday, January 14, 2002 4:01 PM
> Subject: [noparse][[/noparse]basicstamps] Re: Stamp 1 Editor
> Greg
> doesn't
> > port.
> > What type of parallel port do I need (e.g., bidirectional, EPP, ECP,
> > Greg
> > > Al Williams
> > > AWC
> > > * Floating point A/D http://www.al-williams.com/awce/pak9.htm
> to
> > use
> > > > Greg
It's not a cable or power problem. I can program the BS1 when
connected to LPT1, but not LPT2. Windows Device Manager says
everything is OK (i.e., no conflicts), but I notice LPT2 is at memory
adress 3BC instead of the standard 278 (3BC is standard for LPT3).
LPT1 is at the standard 378. Could it be the editor only looks at
these two standard addresses? I'll try changing LPT2's address and
try again.
Greg
like it
problem.
> Al Williams
> AWC
> * 8 channels of PWM
> http://www.al-williams.com/awce/pak5.htm
of "hardware
> > Greg
> > doesn't
parallel
> > > port.
ECP,
> > > Greg
line.
> > > > Al Williams
> > > > AWC
port
> > to
> > > use
> > > > > Greg
> From: shueyville_greg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=-ELXQJclU2-0une0UQJArZaCJDDY8eFzsbv3QJUTrqDHqNykcdeuhm-ESiHwV3NGTs_gw0zBKl0LDK_tT5LJo4o]gregory-wagner@u...[/url
> Sent: Tuesday, January 15, 2002 8:49 AM
> try again.
> Greg
> like it
> problem.
> > Al Williams
> > AWC
> > * 8 channels of PWM http://www.al-williams.com/awce/pak5.htm
> of "hardware
> > > Greg
> > > doesn't
> parallel
> > > > port.
> ECP,
> > > > Greg
> line.
> > > > > Al Williams
> > > > > AWC
> port
> > > to
> > > > use
> > > > > > Greg
I'm not sure how you knew to use 40:8 for the dump range in debug,
but here is the first line of the results...
-d 40:8
0040:0000 78 03 78 02 00 00 80 9F
So, it appears that LPT1 and LPT2 are at the correct address and
there are only two LPTs, right?
Just to verify again LPT2 is functioning I connected my printer to
LPT2 and the BS1 to LPT1. The printer works, but the Stamp editor
gave me a "EEPROM verify failed" error. If I power off the printer I
do not get the error. I can then power the printer back on. So it
seems the editor quasi-detects a BS1 as the printer. But, this isn't
consistent (i.e., I cannot duplicate this everytime). By the way, I'm
running the Stamp editor from a DOS window. It didn't seem to matter
if I re-booted to a DOS prompt.
I'm going to just manually re-connect the BS1 to LPT1 whenever I need
to re-program it. I've only got one BS1 left and it's not worth my
time to troubleshoot this anymore. I'll do my microcontroller
prototyping on the BS2 and production with PIC.
Greg
PS. Anyone in the market for a parallel port card? ;-)
> I'm going to make a guess that the editor looks for the LPT
addresses in
> the BIOS memory area. Start a DOS window and type debug. Then enter:
> D 40:8
> That should show you the LPT addresses (two bytes per address). If
LPT2
> is not correct, that might explain it.
> Oddly, mine shows 4 LPT ports even though I only have 1 LPT port,
so my
> guess is Win XP is fibbing to DOS to catch network printers :-)
> Al Williams
> AWC
> * Control 8 servos at once
> http://www.al-williams.com/awce/pak8.htm
memory
LPT3).
and
> > try again.
> > Greg
> > like it
> > problem.
> > > Al Williams
> > > AWC
> > of "hardware
help
> > > > Greg
wagner@u...>
> > > > doesn't
> > parallel
> > > > > port.
EPP,
> > ECP,
> > > > > Greg
> > line.
> > > > > > Al Williams
> > > > > > AWC
> > port
> > > > to
> > > > > use
> > > > > > > Greg
> From: shueyville_greg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=hQXOXJELtbYGqY5wTCnrG7MPK6qrNOzCfREDJWDq5c_NZMmRJCX-tdql2QaZ7DXEB5092-Qix5-hWhCHGF8xdHg]gregory-wagner@u...[/url
> Sent: Tuesday, January 15, 2002 11:31 AM
> -d 40:8
> Greg
> addresses in
> > D 40:8
> LPT2
> so my
> > Al Williams
> > AWC
> > * Control 8 servos at once http://www.al-williams.com/awce/pak8.htm
> memory
> LPT3).
> and
> > > try again.
> > > Greg
> > > like it
> > > problem.
> > > > Al Williams
> > > > AWC
> > > of "hardware
> help
> > > > > Greg
> wagner@u...>
> > > > > doesn't
> > > parallel
> > > > > > port.
> EPP,
> > > ECP,
> > > > > > Greg
> > > line.
> > > > > > > Al Williams
> > > > > > > AWC
> > > port
> > > > > to
> > > > > > use
> > > > > > > > Greg
No, they are not, I don't think... The second parallel port card has
a jumper for IRQ 5 or 7 (it is an 8-bit ISA). It is set to IRQ 5.
Device Manager shows LPT1 as using IRQ 7, but LPT2 did not show any
IRQ being used which may explain the intermittent problems. IRQ 5 is
shown as being used by another adapter card in my system, but no
conflicts are being reported. I don't have any free IRQs at the
moment, but when time permits I'll remove the card using IRQ 5 and
test again. Thanks for all your suggestions Al.
Greg
> Do you have LPT1 an LPT2 set for the same IRQ by any chance?
> Al Williams
> AWC
> * 8 channels of PWM
> > -d 40:8
printer I
isn't
I'm
matter
need
my
> > Greg
> > addresses in
enter:
> > > D 40:8
If
> > LPT2
port,
> > so my
> > > Al Williams
> > > AWC
> > memory
> > LPT3).
looks at
> > and
> > > > try again.
> > > > Greg
Looks
> > > > like it
other
> > > > problem.
> > > > > Al Williams
> > > > > AWC
> > > > of "hardware
for
> > help
> > > > > > Greg
> > wagner@u...>
but it
> > > > > > doesn't
on a
> > > > parallel
> > > > > > > port.
bidirectional,
> > EPP,
> > > > ECP,
> > > > > > > Greg
command
> > > > line.
> > > > > > > > Al Williams
> > > > > > > > AWC
parallel
> > > > port
> > > > > > to
> > > > > > > use
> > > > > > > > > Greg
Al Williams
AWC
> From: shueyville_greg [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=RudLZmmQaPP7iRsgKAuyALIoPx6LzTHKntgFsN5fOAvKXQKHh_t8RssdzRVsDhB8_ypYy4wgB5OTcIDemubk3_sM5w]gregory-wagner@u...[/url
> Is there a way to tell the Stamp 1 Editor which parallel port to use
> Greg
port.
ECP, ...)
Greg
> Al Williams
> AWC
use
> > Greg
Greg
doesn't
> port.
> ECP, ...)
> Greg
> > Al Williams
> > AWC
to
> use
> > > Greg
Al Williams
AWC
* 8 channels of PWM
> Greg
> doesn't
> > port.
> > Greg
> > > Al Williams
> > > AWC
> to
> > use
> > > > Greg
try again.
Greg
like it
problem.
> Al Williams
> AWC
> * 8 channels of PWM
of "hardware
> > Greg
> > doesn't
parallel
> > > port.
ECP,
> > > Greg
line.
> > > > Al Williams
> > > > AWC
port
> > to
> > > use
> > > > > Greg
D 40:8
That should show you the LPT addresses (two bytes per address). If LPT2
Oddly, mine shows 4 LPT ports even though I only have 1 LPT port, so my
Al Williams
AWC
> try again.
> Greg
> like it
> problem.
> > Al Williams
> > AWC
> of "hardware
> > > Greg
> > > doesn't
> parallel
> > > > port.
> ECP,
> > > > Greg
> line.
> > > > > Al Williams
> > > > > AWC
> port
> > > to
> > > > use
> > > > > > Greg
-d 40:8
Greg
addresses in
> D 40:8
LPT2
so my
> Al Williams
> AWC
memory
LPT3).
and
> > try again.
> > Greg
> > like it
> > problem.
> > > Al Williams
> > > AWC
> > of "hardware
help
> > > > Greg
wagner@u...>
> > > > doesn't
> > parallel
> > > > > port.
EPP,
> > ECP,
> > > > > Greg
> > line.
> > > > > > Al Williams
> > > > > > AWC
> > port
> > > > to
> > > > > use
> > > > > > > Greg
Al Williams
AWC
* 8 channels of PWM
> -d 40:8
> Greg
> addresses in
> > D 40:8
> LPT2
> so my
> > Al Williams
> > AWC
> memory
> LPT3).
> and
> > > try again.
> > > Greg
> > > like it
> > > problem.
> > > > Al Williams
> > > > AWC
> > > of "hardware
> help
> > > > > Greg
> wagner@u...>
> > > > > doesn't
> > > parallel
> > > > > > port.
> EPP,
> > > ECP,
> > > > > > Greg
> > > line.
> > > > > > > Al Williams
> > > > > > > AWC
> > > port
> > > > > to
> > > > > > use
> > > > > > > > Greg
Greg
> Al Williams
> AWC
> * 8 channels of PWM
> > -d 40:8
printer I
isn't
I'm
matter
need
my
> > Greg
> > addresses in
enter:
> > > D 40:8
If
> > LPT2
port,
> > so my
> > > Al Williams
> > > AWC
> > memory
> > LPT3).
looks at
> > and
> > > > try again.
> > > > Greg
Looks
> > > > like it
other
> > > > problem.
> > > > > Al Williams
> > > > > AWC
> > > > of "hardware
for
> > help
> > > > > > Greg
> > wagner@u...>
but it
> > > > > > doesn't
on a
> > > > parallel
> > > > > > > port.
bidirectional,
> > EPP,
> > > > ECP,
> > > > > > > Greg
command
> > > > line.
> > > > > > > > Al Williams
> > > > > > > > AWC
parallel
> > > > port
> > > > > > to
> > > > > > > use
> > > > > > > > > Greg
