motor direction control
Archiver
Hello Everyone,
I am building a mini robot that is going to use mini DC motors for
driving. I am wondering if anyone could tell me how I can easily
control the direction of the motor with the basic stamp? Because of
the lack of space the smallest circuit would be most appropiate.
Thanks in advance!
Travis
Thanks in advance!
Travis
> Thanks in advance!
Two common ways are to use an "H Bridge" or a DPDT relay wired so it
will reverse the wiring to the DC motor. Do a search on "H Bridge" and
you'll find all sorts of info. The relay is probably easier but
perhaps not as elegant.
Tim
several other chips out there. www.alegro.com also has some motor control
chips as well.
Do a search on L298 on the web or goto www.digikey.com and search there, you
can get the specs there as well.
These types of motor control chips work good, in that you don't have to use
PWM, or varying frequency (duty cycle) pulses, unless you really want to.
Basically you allocate four I/O pins to the control. A 0,0 stop, 0,1
forward, 1,0 reverse, 1,1 stop on each pair of pins is all you'd need at the
minimum.
If you want proportional or varying speeds, then take one pin low, and pulse
the other at different frequencies (duty cycle) and you get a simp,le speed
control.
Since the L298 has dual H-bridges you can control two motors for
differential steering.
You can parallel the chips if you need more power.
From: travis_gm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=oUtZmuI_6jFh1MVJIRVNW_434j-9dB3fa5B8CuhHkFY8qW2IK-HKIDXBjNz3WQqfDMHO-R9H3lTd]travis_gm@y...[/url
Sent: Saturday, January 12, 2002 3:04 PM
Subject: [noparse][[/noparse]basicstamps] motor direction control
Hello Everyone,
Thanks in advance!
Travis
600mA per motor. Is rather cheap (3.50 U$), much smaller then the L298 (no
heatsink), directly Basic stamp (/TTL) compatible ,works great for PWM and
uses no external diodes. Got good experience with it.
alternatives for mini robot apps are to handwire a few multipurpose
transistors, diodes and resisitors, but I think you would probably need more
space for that. Especially when your current demands are higher (mostly the
case using toy/cheap motors).
A few links:
http://focus.ti.com/docs/prod/productfolder.jhtml?genericPartNumber=L293D
(datasheet)
http://www.hvwtech.com/motorcontroller.htm (scroll down)
http://members.aol.com/rich924/pub/l293.pdf (schematics)
good luck,
Matthijs
From: travis_gm [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=rZNE4-Mvly18QepkVZCr13__qWk8GZdLEYDg_qOTkAyYnQumfK2qbezQbGEEPCH6x9IxNj0ab8quJtI]travis_gm@y...[/url
Sent: Saturday, January 12, 2002 22:04
Hello Everyone,
Thanks in advance!
Travis
